Ok, here another problem with the theme, this time the guilty is the Atez SilverBlue Theme, a sort of clone of the well know Atez from Hyperion (again with OWB), this time problem start if you open a new tab, see grab:
http://imageshack.us/photo/my-images/534/owb2.png/
As usual I talked with the author of this theme but again he didn't be able to fix, maybe an OWB issue, a bug of the theme or an OS4 issue ?
Anyone with the same issue ?
Atez SilverBlue Theme problems
Re: Atez SilverBlue Theme problems
Just to add, this problem seems a bit different than the one (SilverGreen Theme) reported at:
http://forum.hyperion-entertainment.biz ... f=14&t=163
Is different because it seems affected also the MUI and all the other programs, it seems strictly related to the window "costructor" rathen the the content of a Reaction window
I can provide other grabs if needed
We have found why Atez like theme is broken opening f.e. more than 1 tab in OWB and others under OS 4.1 Update 2.
The cause is the shadows effect related to the compositing, disabling it the bug finally gone and you can use this theme again without any problem
Is it possible to open a new ticket in order to fix it ?
Reported as bug 7187...
Thanks Elwood
