Problem with Catweasel driver
samo79
Post by samo79 »
Since Update 5 we have this new driver onboard by default and this is cool but i need to disabled it completely from my AmigaInput preferences because it crash badly any time i try to start some games/emulators that have a proper Joypad settings already configured (for example GnGeo)
I don't have any Catweasel hardware on my Sam440 so maybe this is the real cause of the crash, but it shouldn't i think .. if one didn't have any hardware suppoted by this driver would be better to just skip, not a crash :-)
Anyone with the same problem ?
If so, maybe someone can open a new report/ticket for that ?
Re: Problem with Catweasel driver
Post by zzd10h »
Just to say that I had exactly the same problem since update5 with UAE.
Crash log for task "Work:Emu/E-UAE_0.8.29-WIP4+_SDL/uae"
Generated by GrimReaper 53.5
Crash occured in module PCI_CatweaselJoystick.driver at address 0x7F463320
Under update4, my USB pad worked like a charm under UAE and since the update5 GrimReaper
each time relating to the catweasel driver.
Since I disabled it on AmigaInput it works great.
samo79
Post by samo79 »
Hi Guillaume, thanks to confirm the problem ;)
Do you have a Pegasos 2 right ?
Post by zzd10h »
Hello Samir,
Yes I have a Pegasos 2.
You think that it can have an impact on catweasel driver ?
samo79
Post by samo79 »
No in this case i don't think so, however sometimes the OS can react different depending on the hardware used, look for example at our recent discussion about SysMon and AmiDock
nubechecorre
Post by nubechecorre »
same problem here with the sam mini-itx.. I also tried to remove the catweasel driver from devs/dosdriver but nothing changed..
http://www.os4games.it
Sam440ep mini-itx
Classic System:
Amiga 1200
Radeon 9250 128Mb VRam
Voodoo 3 3000 16Mb VRam
DVD-RW LG Dual Layer
SoundBlaster PCI 128
Cocolino Interface Elbox
AmigaOne White Mouse
You need to move
from
Libs:AmigaInput
nubechecorre wrote:same problem here with the sam mini-itx.. I also tried to remove the catweasel driver from devs/dosdriver but nothing changed..
nubechecorre
@Spectre660
Sam440ep mini-itx
Classic System:
Amiga 1200
ChrisH
Post by ChrisH »
Just to let you guys know that this problem was reported to the Catweasel driver author a while ago.
samo79
Post by samo79 »
ChrisH wrote:Just to let you guys know that this problem was reported to the Catweasel driver author a while ago.
