Xorg -configure
Xorg -configure
Should the 'Xorg - configure' command work with X5000? I get always this kind of error:
Kernel access of bad area
Segmentation fault
Tested with kernel 5.10 and 5.5. Is this a kernel bug?
Re: Xorg -configure
Roland wrote: Tue Mar 29, 2022 10:47 am Should the 'Xorg - configure' command work with X5000? I get always this kind of error:
Segmentation fault
Did you test it as root?
Re: Xorg -configure
xeno74 wrote: Tue Mar 29, 2022 5:26 pm Did you test it as root?
Of course, that command does not work othervise.
