dhewm3 (Doom3)
dhewm3 (Doom3)
Great news: Bug "No text on BigEndian" fixed
Further information about dhewm3: https://dhewm3.org
Re: dhewm3 (Doom3)
I successfully compiled it today.
Download: dhewm3-1.5.1-linux-powerpc.tar.gz.
It works on Fienix and MintPPC.
For Fienix: You need the package ibjpeg9_9d-1_powerpc.deb. Please install it with dpkg -i before you start dhewm3.
Re: dhewm3 (Doom3)
Screenshot of the new fixed version of dhewm3:
Re: dhewm3 (Doom3)
Display FPS, GPU, CPU, TEMP etc:
GALLIUM_HUD=simple,fps,cpu ./dhewm3
GALLIUM_HUD=GPU-load,cpu0+cpu1+cpu2+cpu3,fps,sensors_temp_cu-radeon-pci-0100.temp1 ./dhewm3
Re: dhewm3 (Doom3)
I also tested dhewm3 with ultra quality settings on my Raspberry Pi 400 with an overclocked quad core CPU (4x 2.2GHz) and an overclocked VideoCore VI GPU and it isn’t as fast as on my AmigaOne X1000 and AmigaOne X5000.
Re: dhewm3 (Doom3)
Thanks, got it installed, seems to run fine but will play with it a bit more. Much appreciated as usual!
Re: dhewm3 (Doom3)
I compiled it for the old Ubuntu 16.04 today.
Download: dhewm3-1.5.1-ubuntu16.04-powerpc.tar.gz
I had to compile a new version of openal-soft as well because it doesn't compile with the default installed openal devel files.
caseycullen
Re: dhewm3 (Doom3)
Post by caseycullen »
Very awesome, Doom3 was one of my favorite games! I'm able to play with good performance on Ultra settings and 1280x720 resolution.
-Casey
Re: dhewm3 (Doom3)
caseycullen wrote: Wed Apr 21, 2021 4:06 pm Very awesome, Doom3 was one of my favorite games! I'm able to play with good performance on Ultra settings and 1280x720 resolution.
-Casey
The new version is better than the old original one from the past. It has many bugfixes, supports EAX-like sound effects, and has much better support for widescreen resolutions.
We have better graphics cards today and can play it with ultra settings.
What do you think about to add it to Fienix?
caseycullen
Re: dhewm3 (Doom3)
xeno74 wrote: Wed Apr 21, 2021 9:36 pmThe new version is better than the old original one from the past. It has many bugfixes, supports EAX-like sound effects, and has much better support for widescreen resolutions.
Yep, I'll add it and the other required package today.
-Casey
