Kernel 5.2
Kernel 5.2
The Linux 5.2 merge window is now open so I released the first alpha today.
  • X1000: pata_of_platform-v2 patch for solving the issues with new CF cards connected to the onboard CompactFlash Card Slot
  • X1000: Disabling the kernel config options CONFIG_PATA_PCMCIA, CONFIG_PCMCIA, and CONFIG_ELECTRA_CF for the pata_of_platform-v2 patch
Further information: CF cards test thread
Issue:
Download: linux-image-5.2-alpha1-X1000_X5000.tar.gz
Screenshot of Fienix PowerPC with the first alpha of kernel 5.2:
@SailorMH
Please test the first alpha with your CF cards.
Re: Kernel 5.2
Kernel 5.2 Alpha 1 up and running on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 190443.png
Re: Kernel 5.2
Skateman wrote:Kernel 5.2 Alpha 1 up and running on the AmigaOne X5000
Thanks a lot for testing the alpha1. :-)
Re: Kernel 5.2
Here is the alpha2 of kernel 5.2 for testing.
Download: linux-image-5.2-alpha2-X1000_X5000.tar.gz
@SailorMH
@Ace
Please test it with your two installed graphics cards.
Re: Kernel 5.2
Kernel 5.2 Alpha2 running on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 210034.png
Re: Kernel 5.2
Skateman wrote:Kernel 5.2 Alpha2 running on the AmigaOne X5000
Re: Kernel 5.2
Success, 5.2 boots to Firepro, thank you for all your hard work. One small issue, I can no longer use my Logitech wireless usb mouse, did anything change in that regard. Corded usb mouse work fine. Once again great work, much appreciated.
Re: Kernel 5.2
acefnq wrote:Christian
Hi Ace,
Great, that your two graphics cards work with the alpha2! :-)
Have you installed the kernel modules because of your USB wireless mouse yet?
Re: Kernel 5.2
Yes I installed modules here: /lib/modules/5.2-a2_A-EON_X5000-08122-ga2d635d-dirty.
Cheers
Re: Kernel 5.2
Cheers
Hi Ace,
OK. Please post the output of xinput list with your connected wireless USB mouse with the final kernel 5.1 and with the alpha2 of kernel 5.2.
