HD’s prep
Tijatjj
HD’s prep
Post by Tijatjj »
Hi have a one gig HD looking to put Linux on it with Amiga os so what format & file system would I be using thanks . Also would I make it boot able and priority over Amiga partition .Would I use Amiga format or some other right now I have part of it on usb Thank you
Re: HD’s prep
Tijatjj wrote:Hi have a one gig HD looking to put Linux on it with Amiga os so what format & file system would I be using thanks . Also would I make it boot able and priority over Amiga partition .Would I use Amiga format or some other right now I have part of it on usb Thank you
Hi Tijatjj,
Which graphics card is installed in your X5000? Which Linux distribution do you want to install?
Tijatjj
Re: HD’s prep
Post by Tijatjj »
Ubuntu and it’s a Radeon sff 7750 2 gig ,actually I don’t care which Linux but that’s the only one I could get to unpacked another gentleman me I just need to change the redirect mirror because this one was not working thanks
Re: HD’s prep
Tijatjj wrote:Ubuntu and it’s a Radeon sff 7750 2 gig ,actually I don’t care which Linux but that’s the only one I could get to unpacked another gentleman me I just need to change the redirect mirror because this one was not working thanks
Please note: You don't have hardware 3D acceleration with your graphics card on Ubuntu. That means, Ubuntu isn't as fast as with a compatible graphics card (Radeon HD6xxx and below).
Tijatjj
Re: HD’s prep
Post by Tijatjj »
Ok thank you why is there something faster Linux version.
Re: HD’s prep
Tijatjj wrote:Ok thank you why is there something faster Linux version.
Hi Tijatjj,
I am sorry, I don't understand your question. Could you please write your question with another sentence again?
Tijatjj
Re: HD’s prep
Post by Tijatjj »
Please excuse,you mentioned no hardware acceleration on graphics with Ubuntu .is there another Linux disttro that would support it thank you
Re: HD’s prep
Tijatjj wrote:Please excuse,you mentioned no hardware acceleration on graphics with Ubuntu .is there another Linux disttro that would support it thank you
Unfortunately not. You need a Radeon HD6xxx or below.
— Christian
Tijatjj
Re: HD’s prep
Post by Tijatjj »
Thanks got it
