SuperTux
SuperTux
There are sound issues in the default package of SuperTux on Linux PPC. I was able to solve this issue with:
vi SuperTux-v0.5.1-Source/src/audio/ogg_sound_file.cpp:
#ifdef WORDS_BIGENDIAN
    int bigendian = 1;
#else
    int bigendian = 1;
#endif
The problem was, that this source code doesn't detect our BIG ENDIAN platform. I added int bigendian = 1; after #else and after compiling, the sound and music work without any problems.
I uploaded it for testing today. You can start it with ./run_game.sh.
Download: supertux-0.5.1-linux-glibc2.23-ppc.tar.gz
Screenshot:
Re: SuperTux
If your system has hardware 3D acceleration support then you can use it with SuperTux. :-) Please add --renderer opengl to the SuperTux command in the script run_game.sh. After that SuperTux works faster! :-) I tested it with a Radeon HD4870 (AmigaOne X5000) and with a Radeon HD6870 (AmigaOne X1000) on ubuntu MATE 16.04.5 LTS and on the MATE PowerPC Remix 0.9.
Re: SuperTux
Thanks, works very well with --renderer opengl added.
Re: SuperTux
acefnq wrote:Thanks, works very well with --renderer opengl added.
Good to know! :-) Thank you! :-)
Re: SuperTux
BTW, SuperTux works also on Debian. :-)
Screenshot of Debian PowerPC with kernel 4.20-rc5 and with SuperTux 0.5.1:
Re: SuperTux
Great news! :-)
Casey released the new SuperTux 0.6.0 for Fienix PowerPC today! You can install it with the package management system (APT, Synaptic .. etc).
LiveForIt
Re: SuperTux
Post by LiveForIt »
xeno74 wrote:Hi All,
    int bigendian = 1;
#else
    int bigendian = 1;
#endif
You should fix this in the "makefile", normaly there is like $(OPTS) or some thing you can add -DWORDS_BIGENDIAN
bigendian = 0 is correct after #else
Re: SuperTux
LiveForIt wrote: You should fix this in the "makefile", normaly there is like $(OPTS) or some thing you can add -DWORDS_BIGENDIAN
Thanks a lot for the hint!
— Christian
Re: SuperTux
A Christmas present for you. :-) The new SuperTux 0.6.3. :-)
New: supertux.org
Download: supertux-0.6.3-linux-glibc2.23-ppc.tar.gz
You can start it with ./run_game.sh. I successfully tested it on ubuntu MATE 16.04.7, Void PPC, MintPPC, and on Fienix today.
Screenshot:
I wish you a Merry Christmas and thanks a lot for your help with testing! :-)
Re: SuperTux
You can also use OpenGL as renderer.
Please replace sdl with opengl20 in the file run_game.sh.
export LD_LIBRARY_PATH=./bin/
bin/supertux2 --datadir ./data/ --renderer opengl20
