Kernel 4.19
Kernel 4.19
The Linux 4.19 kernel merge window is open for merging. Linus Torvalds has added a lot of new source code to the Linux Git. Darren created a new Nemo patch for our AmigaOne X1000 last week. He'll split it into a couple of patches and then he will submit these to the Linux kernel developers. I created the first alpha with Darren's new patch today.
Download: vmlinux-4.19-alpha1-AmigaOne_X1000_X5000.tar.gz
Re: Kernel 4.19
Kernel 4.19-A1 running on my X5000 :-)
Re: Kernel 4.19
Skateman wrote:Kernel 4.19-A1 running on my X5000 :-)
Thank you! :-)
Re: Kernel 4.19
Here is the alpha2 for testing.
Download: vmlinux-4.19-alpha2-AmigaOne_X1000_X5000.tar.gz
Re: Kernel 4.19
Alpha 2 running on my X5000! :-)
Re: Kernel 4.19
Skateman wrote:Alpha 2 running on my X5000! :-)
Re: Kernel 4.19
I compiled the alpha3 of kernel 4.19 for testing today.
Download: vmlinux-4.19-alpha3-AmigaOne_X1000_X5000.tar.gz
PLEASE test it.
Re: Kernel 4.19
Alpha 3 running fine on the X5000 :-)
Will test the DPAA onboard ethernet later today.
Re: Kernel 4.19
To bad,.. even more issues with the DPAA Ethernet part.
(Click http://www.skateman.nl/wp-content/uploa ... 202817.jpg for a bigger screenshot)
In the past the MII-tool did respond but now the outcome is:
SIOCGMIIPHY on 'eth0' failed: Invalid argument
SIOCGMIIPHY on 'eth1' failed: Invalid argument
no MII interfaces found
The DPAA Ethernet adapter does get probed.
[ 5.878766] fsl_dpaa_mac ffe4e6000.ethernet eth0: Probed interface eth0
[ 5.885851] fsl_dpaa_mac ffe4e8000.ethernet eth1: Probed interface eth1
Ethtool does give some info..
skateman@X5000LNX:~$ ethtool eth0
Settings for eth0:
Supported ports: [ MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Speed: 10Mb/s
Duplex: Half
Port: MII
PHYAD: 3
Transceiver: external
Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
Current message level: 0x00000037 (55)
drv probe link ifdown ifup
Link detected: no
The DPAA Eth0 is connected to a Gigabit Switch but no activity or link led.
Will try to do some more testing..
Re: Kernel 4.19
Skateman wrote:Alpha 3 running fine on the X5000 :-)
Many thanks for testing the alpha3 and thanks for testing the DPAA Ethernet. Sorry because of the bad test results with the DPAA Ethernet.
