Why is Radeon SI graphics cards not 3D supported?
johnfante
Post by johnfante »
It is NOT a complaint :-)
Just curious to why 3D acceleration is not supported on Radeon SI graphics cards on PPC linux. And if there are any signs that this will happend down the road.
It has maybe been covered before and in this case sorry in advance!
Thank you in advance!
X5000 :-)
Re: Why is Radeon SI graphics cards not 3D supported?
JohnFante wrote:It is NOT a complaint :-)
See the following threads:
johnfante
Post by johnfante »
So in short it is caused by primarly this:
Glamor Crashes on big endian Hardware https://bugs.freedesktop.org/show_bug.cgi?id=99859
The thread is from 2017 and no solution is in sight .... as far as I can read on a quick glance.
Ok. Thank you for the reply :-). I am keeping my fingers crossed for a solution.
And thank you for all your work for PPC linux.
X5000 :-)
If you use a Radeon SI graphics card then please try the following xorg.conf:
/etc/X11/xorg.conf:
Section "Device"
    Option "UseFBDev" "true"
    Identifier  "Card0"
EndSection
johnfante
Post by johnfante »
xeno74 wrote:Hi All,
/etc/X11/xorg.conf:
Section "Device"
    Identifier  "Card0"
EndSection
Will do. Is it important what kernel is used?
X5000 :-)
johnfante
Post by johnfante »
/etc/X11/xorg.conf:
Section "Device"
    Identifier  "Card0"
EndSection
I have tested with a fully updated Fienix and kernel 5.3. I am sorry to say that it does not work with a solo Radeon SI card.
Here is the xorg.conf before I rebooted: https://www.dropbox.com/s/1vp6bhcndzl1e ... .jpeg?dl=0
Here is the result: https://www.dropbox.com/s/p16wi7phmxx42 ... .jpeg?dl=0
I can not get past the white screen.
I will try adding my Firepro to see if that helps.
X5000 :-)
JohnFante wrote: I have tested with a fully updated Fienix and kernel 5.3. I am sorry to say that it does not work with a solo Radeon SI card.
It works here with a Radeon R7 240 and with the xorg.conf above.
johnfante
Post by johnfante »
I have a R9 270X 2GB installed in mine. Strange! :?:
The R7 240 and the R9 270X should be the same architecture: https://en.wikipedia.org/wiki/AMD_Radeon_Rx_200_series
X5000 :-)
JohnFante wrote: I have a R9 270X 2GB installed in mine. Strange! :?:
Please try the following xorg.conf:
Section "Device"
    Identifier  "Card0"
    Driver      "fbdev"
EndSection
