caseycullen
Posts: 528 Joined: Sat Dec 17, 2016 7:12 am
Post
by caseycullen » Tue Jan 15, 2019 5:40 pm
Hi Christian,
Please try to install streamtuner2 and openssh-server. Let me know if you have any issues.
-Casey
Could you please add the package
openssh-server to your repository?
I love
StreamTuner2 for listening to the internet radio. Is it possible to add it to your repository?
caseycullen
Post
by caseycullen » Tue Jan 15, 2019 5:57 pm
Roland wrote: Thanks a lot, got it to work! There is one small side effect, though... When I log out, to change the account, the 'autologin' stays still active and relogins to the original account after a timeout. It is of course possible to give to the "autologin-user-timeout" a relatively high value, so that you have time to input the new login data, but it will also slow down the initial boot process. Would it be possible to somehow disable this 'autologin' when you log out to change the user?
I've never tried. I'll experiment a bit.
Roland wrote: Some companies still use stubbornly Flash, e.g. for seat selection or for copy protection reasons ... And if they happen to have a monopoly in their area, they do not need to listen to their customers :-/.
Did Gnash (the Flash plugin in Debian 8) work for you? We can see if we can get it working in Fienix.
-Casey
caseycullen
Post
by caseycullen » Tue Jan 15, 2019 6:25 pm
Kmahjongg has a lot of KDE library dependencies I'd like to avoid if possible. Could you try xmahjongg? I've added it to the Fienix repository.
-Casey
acefnq wrote: Casey
Can confirm Alephone (Marathon1 and 2) all work again. Thanks for your efforts. Any chance of getting KMahjongg working? Perhaps a lond shot but it is what relaxes me -:)
Great work
Allan
Posts: 11502 Joined: Fri Mar 23, 2012 7:58 am
Post
by xeno74 » Tue Jan 15, 2019 7:49 pm
caseycullen wrote: Hi Christian,
-Casey
Many thanks!
I will try to install these packages tomorrow.
— Christian
Posts: 943 Joined: Tue May 02, 2017 8:23 am
Post
by Roland » Wed Jan 16, 2019 7:53 am
caseycullen wrote: Did Gnash (the Flash plugin in Debian 8) work for you? We can see if we can get it working in Fienix.
It is so far the best on of those I have tested... Not perfect but useful anyway.
Post
by xeno74 » Thu Jan 17, 2019 8:17 am
Hi Casey,
StreamTuner2 works! Many thanks!
I wasn't able to install the OpenSSH server because OpenSSH SFTP isn't installable and the OpenSSH client is too old.
openssh-server:
Depends: openssh-client (=1:7.9p1-5) but 1:7.9p1-4 is to be installed
Depends: openssh-sftp-server but it is not going to be installed
openssh-sftp-server:
johnfante
Posts: 190 Joined: Tue Sep 04, 2012 7:48 am
Post
by johnfante » Thu Jan 17, 2019 8:25 pm
Great distribution
Two questions:
1) I was trying to update the distribution with apt-get update and apt-get upgrade but gets a strange dpkg-error. See output below. Is that normal? I use the stable 4.20 kernel.
fienix@Fienix:~$ su
Password:
root@Fienix:/home/fienix# apt-get update
Hit:1 http://ppcutopia.ddns.net/repos/apt/debian sid InRelease
Hit:2 http://ppcutopia.ddns.net/repos/apt/debian fienix InRelease
Reading package lists... Done
root@Fienix:/home/fienix# apt-get upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
alsa-base apache2-bin aptitude-doc-en blueman bluez caja-admin caja-eiciel
caja-extensions-common caja-gtkhash caja-open-terminal caja-rename
caja-sendto caja-wallpaper coinor-libcbc3 coinor-libcgl1 coinor-libclp1
coinor-libcoinmp1v5 coinor-libcoinutils3v5 coinor-libosi1v5
compiz-plugins-default compiz-plugins-extra compton cpp-4.9 cpufrequtils
crda cryptsetup-bin dconf-cli dconf-editor dh-python dmz-cursor-theme
dnsmasq-base docbook-xml docutils-common docutils-doc eom eom-common
espeak-data espeak-ng-data ffmpegthumbnailer gcc-6-base
gir1.2-appindicator3-0.1 gir1.2-atspi-2.0 gir1.2-caja gir1.2-caja-2.0
gir1.2-gtk-2.0 gir1.2-gtksource-3.0 gir1.2-matedesktop-2.0 gir1.2-pluma-1.0
gnome-icon-theme-symbolic gnome-system-tools gstreamer0.10-alsa
gstreamer0.10-gconf gstreamer0.10-plugins-base gstreamer0.10-x gtkhash
hddtemp hdparm hyphen-en-us imagemagick-6-common iputils-arping iw
javascript-common libabw-0.1-1 libalgorithm-c3-perl libamd2.3.1 libao-common
libao4 libapache2-mod-dnssd libappindicator3-1 libaprutil1-dbd-sqlite3
libaprutil1-ldap libarchive-extract-perl libart-2.0-2 libasprintf0c2
libatk-adaptor libatkmm-1.6-1v5 libavcodec56 libavformat56 libavresample2
libavutil54 libb-hooks-endofscope-perl libb-hooks-op-check-perl libb2-1
libbabl-0.1-0 libbind9-90 libblas-common libbluetooth3 libbluray1
libboost-chrono1.62.0 libboost-date-time1.62.0 libboost-date-time1.67.0
libboost-filesystem1.62.0 libboost-filesystem1.67.0 libboost-iostreams1.62.0
libboost-iostreams1.67.0 libboost-locale1.62.0 libboost-system1.55.0
libboost-system1.62.0 libboost-system1.67.0 libboost-thread1.62.0
libbrlapi0.6 libcairomm-1.0-1v5 libcamd2.3.1 libccolamd2.8.0 libcdio-cdda1
libcdio-paranoia1 libcdio13 libcdr-0.1-1 libcgi-fast-perl libcgi-pm-perl
libcholmod2.1.2 libclass-accessor-perl libclass-c3-perl libclass-c3-xs-perl
libclass-method-modifiers-perl libclass-xsaccessor-perl libcloog-isl4
libclucene-contribs1v5 libclucene-core1v5 libcmis-0.5-5v5 libcolamd2
libcolamd2.8.0 libconfig9 libcpan-changes-perl libcpan-meta-perl libcpufreq0
libcurl4 libdata-optlist-perl libdata-perl-perl libdata-section-perl
libdbus-1-dev libdevel-callchecker-perl libdevel-globaldestruction-perl
libdevmapper-event1.02.1 libdirectfb-1.2-9 libdns100 libdotconf0
libdpkg-perl libdw1 libdynaloader-functions-perl libe-book-0.1-1 libelfg0
libeot0 libept1.4.12 libepubgen-0.1-1 libespeak-ng1 libespeak1
libetonyek-0.1-1 libevent-2.0-5 libexporter-tiny-perl libexttextcat-2.0-0
libexttextcat-data libfcgi-perl libffmpegthumbnailer4v5
libfile-copy-recursive-perl libfile-fcntllock-perl libfile-slurp-perl
libfreehand-0.1-1 libgcr-3-common libgdbm5 libgegl-0.2-0
libgetopt-long-descriptive-perl libgif4 libgimp2.0 libgksu2-0 libglew1.10
libglibmm-2.4-1v5 libgltf-0.0-0 libgnome-keyring-common libgnome-keyring0
libgraphicsmagick-q16-3 libgstreamer-plugins-base0.10-0 libgstreamer0.10-0
libgtkmm-3.0-1v5 libgtksourceview-3.0-1 libgtksourceview-3.0-common
libgtksourceview2.0-0 libgtksourceview2.0-common libgtop2-7
libgucharmap-2-90-7 libhsqldb1.8.0-java libhunspell-1.3-0 libicu-le-hb0
libicu60 libilmbase6 libimobiledevice4 libimport-into-perl libintl-perl
libio-string-perl libisc95 libisccc90 libisccfg90 libisl10 libisl15 libiw30
libjasper1 libjavascriptcoregtk-3.0-0 libjim0.75 libjxr-tools libjxr0
liblangtag-common liblangtag1 liblist-moreutils-perl libllvm6.0
liblog-message-perl liblog-message-simple-perl liblouis2 liblqr-1-0
liblvm2app2.2 liblwres90 liblzo2-2 libmagickcore-6.q16-6
libmagickwand-6.q16-6 libmate-sensors-applet-plugin0 libmatedict6
libmetacity1 libmhash2 libmodule-build-perl libmodule-implementation-perl
libmodule-pluggable-perl libmodule-runtime-perl libmodule-signature-perl
libmoo-perl libmoox-handlesvia-perl libmpfr4 libmro-compat-perl
libmspub-0.1-1 libmwaw-0.3-3 libmythes-1.2-0 libnamespace-autoclean-perl
libnamespace-clean-perl libndp0 libneon27-gnutls libnetpbm10
libnl-route-3-200 libnm-glib-vpn1 libnm-glib4 libnm-gtk-common libnm-gtk0
libnm-util2 libnm0 libnma0 libntdb1 libnumbertext-1.0-0 libnumbertext-data
libode1 libodfgen-0.1-1 libopencore-amrnb0 libopencore-amrwb0 libopenexr6
libopenjpeg5 libopenobex2 libopenraw1 libopenvg1-mesa liborcus-0.13-0
liborcus-0.8-0 libpackage-constants-perl libpackage-stash-perl
libpackage-stash-xs-perl libpagemaker-0.0-0 libpango1.0-0 libpangomm-1.4-1v5
libparams-classify-perl libparams-util-perl libparams-validate-perl
libparse-debianchangelog-perl libpath-tiny-perl libpcaudio0
libpeas-1.0-python2loader libperl4-corelibs-perl libperl5.26 libplist2
libpng12-0 libpod-latex-perl libpod-markdown-perl libpod-readme-perl
libpoppler46 libpoppler74 libprotobuf10 libprotobuf17 libpth20 libpython3.6
libpython3.6-minimal libpython3.6-stdlib libqmi-glib1 libqpdf13 libqxp-0.0-0
libraptor2-0 librarian0 librasqal3 librdf0 libreadonly-perl libref-util-perl
libref-util-xs-perl libregexp-common-perl librevenge-0.0-0 librole-tiny-perl
libschroedinger-1.0-0 libsctp1 libsgutils2-2 libsigc++-2.0-0v5 libsndio6.1
libsnmp-base libsnmp30 libsoftware-license-perl libsonic0 libspeechd2
libssl1.0.2 libstaroffice-0.0-0 libstrictures-perl libsub-exporter-perl
libsub-exporter-progressive-perl libsub-identify-perl libsub-install-perl
libsub-quote-perl libsuitesparseconfig5 libswscale3 libteamdctl0
libterm-ui-perl libtext-template-perl libtext-unidecode-perl
libtokyocabinet9 libtxc-dxtn-s2tc0 libtype-tiny-perl libu2f-udev
libumfpack5.6.2 libunbound2 libunicode-utf8-perl libunique-1.0-0 libusbmuxd2
libva1 libvariable-magic-perl libvisio-0.1-1 libvpx1 libvte-2.90-9
libvte-2.90-common libvte-common libvte9 libwayland-egl1-mesa
libwebkitgtk-3.0-0 libwebp5 libwebpdemux1 libwebpmux1
libwebrtc-audio-processing-0 libwmf0.2-7 libwnck-common libwnck22
libwpd-0.10-10 libwpg-0.3-3 libwps-0.3-3 libwps-0.4-4 libx264-142
libx264-152 libx265-160 libxapian22 libxfont1 libxml-libxml-perl
libxml-namespacesupport-perl libxml-sax-base-perl libxml-sax-expat-perl
libxml-sax-perl libxmlsec1 libxmlsec1-nss libyajl2 libzmf-0.0-0 lksctp-tools
lp-solve mate-applets mate-applets-common mate-calc mate-calc-common
mate-indicator-applet mate-indicator-applet-common mate-media
mate-media-common mate-menu mate-sensors-applet mate-sensors-applet-common
mate-system-monitor mate-system-monitor-common mate-tweak mate-user-share
mate-user-share-common mate-utils mate-utils-common metacity-common
mobile-broadband-provider-info mozo netpbm network-manager
node-normalize.css obex-data-server openjdk-10-jre perl-modules-5.26
pkg-config pluma pluma-common policykit-1-gnome pulseaudio-module-bluetooth
python-caja python-caja-common python-configobj python-dbus python-dbus-dev
python-defusedxml python-docutils python-gst0.10 python-imaging
python-libxml2 python-olefile python-pexpect python-pil python-ptyprocess
python-pycurl python-pygments python-renderpm python-reportlab
python-reportlab-accel python-roman python-setproctitle python-soappy
python-wstools python-xlib python3-brlapi python3-dbus python3-distutils
python3-gst-1.0 python3-lib2to3 python3-louis python3-pexpect python3-psutil
python3-ptyprocess python3-pyatspi python3-renderpm python3-reportlab
python3-reportlab-accel python3-setproctitle python3-speechd python3.6
python3.6-minimal rarian-compat rename sgml-base sgml-data sound-icons
speech-dispatcher speech-dispatcher-audio-plugins
speech-dispatcher-espeak-ng sudo tcpd tex-common udisks wireless-regdb
x11-apps x11-session-utils xbrlapi xinit xml-core xorg
Use 'apt autoremove' to remove them.
The following packages have been kept back:
exim4-base exim4-daemon-light ffmpeg fonts-noto-hinted groff-base iptables
isc-dhcp-client libavdevice58 libavformat58 libavresample4 libavutil56
libenchant1c2a libffms2-4 libip4tc0 libip6tc0 libiptc0
libmate-sensors-applet-plugin0 libpostproc55 libsane-common
libservlet3.1-java libswresample3 libswscale5 libxtables12 lm-sensors
mate-sensors-applet mesa-utils ntfs-3g printer-driver-gutenprint sane-utils
The following packages will be upgraded:
adwaita-icon-theme anacron apt apt-utils atril atril-common bash-completion
bind9-host brasero-common bsdutils caja caja-common compiz-core
compiz-plugins compiz-plugins-default compiz-plugins-extra
compiz-plugins-main console-setup console-setup-linux cpp-8 cups
cups-browsed cups-bsd cups-client cups-common cups-core-drivers cups-daemon
cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc
cups-server-common dash dbus dbus-user-session dbus-x11 dconf-cli
dconf-editor dconf-gsettings-backend dconf-service default-jre
default-jre-headless dirmngr dmsetup e2fsprogs enchant engrampa
engrampa-common exim4-config fdisk fienix-panel fienix-wallpapers-standard
fonts-liberation fonts-noto-mono fonts-opensymbol
foomatic-db-compressed-ppds foomatic-db-engine gcc-8-base gcr gdisk
ghostscript gir1.2-atk-1.0 gir1.2-caja gir1.2-caja-2.0 gir1.2-freedesktop
gir1.2-gdkpixbuf-2.0 gir1.2-glib-2.0 gir1.2-gtk-3.0 gir1.2-gtksource-3.0
gir1.2-javascriptcoregtk-4.0 gir1.2-notify-0.7 gir1.2-pango-1.0
gir1.2-peas-1.0 gir1.2-rb-3.0 gir1.2-secret-1 gir1.2-soup-2.4
gir1.2-vte-2.91 gir1.2-webkit2-4.0 gir1.2-wnck-3.0 glib-networking
glib-networking-common glib-networking-services gnupg gnupg-l10n gnupg-utils
gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv
gtk-update-icon-cache gvfs gvfs-backends gvfs-common gvfs-daemons gvfs-libs
hardinfo init init-system-helpers iproute2 isc-dhcp-common java-common
keyboard-configuration krb5-locales libaacs0 libapparmor1 libapr1
libapt-inst2.0 libapt-pkg5.0 libarchive13 libasound2 libasound2-data libass9
libassuan0 libatk1.0-0 libatk1.0-data libatkmm-1.6-1v5 libatomic1
libatrildocument3 libatrilview3 libbind9-161 libblas3 libblkid1
libbrasero-media3-1 libbrlapi0.6 libc-bin libc-dev-bin libc-l10n libc6
libc6-dev libcairo-gobject2 libcairo2 libcairomm-1.0-1v5 libcaja-extension1
libcanberra-gtk3-0 libcanberra-gtk3-module libcanberra0 libcdio18
libcdr-0.1-1 libcmis-0.5-5v5 libcolamd2 libcom-err2 libcpufreq0 libcroco3
libcryptsetup12 libcryptui0a libcups2 libcupsfilters1 libcupsimage2
libdbus-1-3 libdbus-1-dev libdconf1 libdebconfclient0 libdecoration0
libdee-1.0-4 libdevmapper1.02.1 libdmapsharing-3.0-2 libdns1104 libdw1
libedit2 libegl-mesa0 libegl1-mesa libelf1 libetonyek-0.1-1 libext2fs2
libfdisk1 libfontembed1 libgail-3-0 libgbm1 libgcc1 libgck-1-0
libgcr-base-3-1 libgcr-ui-3-1 libgdata-common libgdata22 libgdk-pixbuf2.0-0
libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgfortran5
libgirepository-1.0-1 libgl1-mesa-dri libgl1-mesa-glx libglapi-mesa
libglibmm-2.4-1v5 libglx-mesa0 libgnutls-dane0 libgnutls-openssl27
libgnutls30 libgoa-1.0-0b libgoa-1.0-common libgomp1 libgpg-error-l10n
libgpg-error0 libgphoto2-6 libgphoto2-l10n libgphoto2-port12
libgraphene-1.0-0 libgs9 libgs9-common libgsm1 libgssapi-krb5-2
libgssdp-1.0-3 libgtk-3-0 libgtk-3-bin libgtk-3-common libgtkmm-3.0-1v5
libgtksourceview-3.0-1 libgtksourceview-3.0-common libgtop-2.0-11
libgtop2-common libgucharmap-2-90-7 libgupnp-1.0-4 libgupnp-igd-1.0-4
libgxps2 libharfbuzz-icu0 libharfbuzz0b libhogweed4 libinput-bin libinput10
libisc1100 libisccc161 libisccfg163 libjansson4 libjavascriptcoregtk-4.0-18
libjson-glib-1.0-0 libjson-glib-1.0-common libk5crypto3 libkpathsea6
libkrb5-3 libkrb5support0 liblapack3 libldap-common liblirc-client0 libllvm7
liblwres161 libmetacity1 libmount1 libmp3lame0 libmpfr6 libnettle6
libnghttp2-14 libnorm1 libnotify4 libnss3 libopenjp2-7 libopenmpt-modplug1
libopenmpt0 libopus0 libpam-systemd libpango-1.0-0 libpango1.0-0
libpangocairo-1.0-0 libpangoft2-1.0-0 libpangomm-1.4-1v5 libpangoxft-1.0-0
libpaper-utils libpaper1 libpeas-1.0-0 libpeas-1.0-python2loader
libpeas-common libperl5.28 libpixman-1-0 libpng16-16 libpolkit-agent-1-0
libpolkit-backend-1-0 libpolkit-gobject-1-0 libprotobuf-lite17 libprotobuf17
libproxy1v5 libpython3-stdlib libpython3.6 libpython3.6-minimal
libpython3.6-stdlib libpython3.7 libpython3.7-minimal libpython3.7-stdlib
libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5opengl5 libqt5svg5
libqt5widgets5 libqt5x11extras5 libqxp-0.0-0 librhythmbox-core10
libsecret-1-0 libsecret-common libsigc++-2.0-0v5 libsmartcols1 libsmbclient
libsoundtouch1 libsoup-gnome2.4-1 libsoup2.4-1 libsqlite3-0 libss2
libssh-gcrypt-4 libstartup-notification0 libstdc++6 libsuitesparseconfig5
libsystemd0 libtbb2 libtcl8.6 libtk8.6 libtotem-plparser-common
libtotem-plparser18 libudev1 libuuid1 libv4l-0 libv4lconvert0 libvdpau1
libvte-2.91-0 libvte-2.91-common libwavpack1 libwbclient0
libwebkit2gtk-4.0-37 libwnck-3-0 libwnck-3-common libwpd-0.10-10
libwpg-0.3-3 libxcb-composite0 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0
libxcb-icccm4 libxcb-present0 libxcb-randr0 libxcb-render0 libxcb-shape0
libxcb-shm0 libxcb-sync1 libxcb-xfixes0 libxcb-xinerama0 libxcb-xkb1
libxcb-xv0 libxcb1 libxklavier16 libxml2 libyelp0 libzstd1 libzvbi-common
libzvbi0 lightdm-gtk-greeter linux-libc-dev locales materia-gtk-theme
mesa-va-drivers mesa-vdpau-drivers metacity-common mount multiarch-support
notification-daemon openprinting-ppds papirus-icon-theme perl perl-base
perl-modules-5.28 policykit-1 printer-driver-escpr publicsuffix python-dbus
python-gi python-gobject python-pkg-resources python-six python3
python3-brlapi python3-dbus python3-gi python3-gi-cairo python3-gst-1.0
python3-markupsafe python3-minimal python3-pkg-resources
python3-pysimplesoap python3-renderpm python3-reportlab
python3-reportlab-accel python3-six python3.6 python3.6-minimal python3.7
python3.7-minimal qt5-gtk-platformtheme qttranslations5-l10n rhythmbox
rhythmbox-data rhythmbox-plugin-cdrecorder rhythmbox-plugins rsyslog
samba-libs seahorse-daemon sed systemd systemd-sysv sysvinit-utils
task-english task-print-server tasksel tasksel-data tcl8.6 tk8.6 tzdata ucf
udev uno-libs3 util-linux util-linux-locales vdpau-driver-all wget
wpasupplicant xbrlapi xdg-user-dirs xterm yelp zenity zenity-common
419 upgraded, 0 newly installed, 0 to remove and 29 not upgraded.
Need to get 0 B/384 MB of archives.
After this operation, 16.8 MB disk space will be freed.
Do you want to continue? [Y/n] Y
Reading changelogs... Done
Extracting templates from packages: 100%
Preconfiguring packages ...
dpkg: warning: 'ldconfig' not found in PATH or not executable
dpkg: warning: 'start-stop-daemon' not found in PATH or not executable
dpkg: error: 2 expected programs not found in PATH or not executable
Note: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin
E: Sub-process /usr/bin/dpkg returned an error code (2)
2) Any suggestions for the best xorg.conf for a Radeon SI card? I was getting the grey boot screen so I copied my xorg.conf from my Ubuntu 16.04 distribution. Now it boots fine but everything is REALLY slow because it uses the "fbdev" driver. At the moment I have:
Section "Monitor"
Identifier "Monitor0"
EndSection
Section "Device"
Identifier "Device0"
Driver "fbdev"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
Any suggestions?
Thankyou in advance!
X5000
Post
by Roland » Sun Jan 20, 2019 9:41 pm
Is there currently in Fienix some way to download videos (from Youtube and other sources) on disk?
caseycullen
Post
by caseycullen » Tue Jan 22, 2019 2:37 am
Above the video you should see a button with the word "Get" in purple. That downloads the video for you.
-Casey
Roland wrote: Is there currently in Fienix some way to download videos (from Youtube and other sources) on disk?
caseycullen
Post
by caseycullen » Tue Jan 22, 2019 3:53 am
Thanks!
Regarding the error:
Please open a terminal window and login as su
Enter "nano /root/.bashrc"
Make sure the following appears at the bottom of the file, add it if it doesn't:
"export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
Let me know if this helps.
Also, do not "apt-get autoclean" at this time.
Radeon SI cards unfortunately do not have hardware acceleration on PowerPC Linux, including Fienix. Your system should not be less responsive than it was on Ubuntu though (unless you're running Ubuntu from an internal drive and Fienix off a USB or something like that). Does Fienix seem noticeably slower than Ubuntu?
-Casey
JohnFante wrote: Great distribution
Two questions:
fienix@Fienix:~$ su
Password:
Section "Monitor"
EndSection
Section "Device"
Driver "fbdev"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Any suggestions?
