Kernel 5.1
Re: Kernel 5.1
DRM4 boots to SI card.
Cheers
Re: Kernel 5.1
acefnq wrote:Christian
Cheers
Thank you for testing! :-) Next step.
git bisect bad
Output:
Bisecting: 45 revisions left to test after this (roughly 6 steps)
[a2b50babc74394c99638a37a3d48adeb03ddc248] drm/sti: Use drm_atomic_helper_shutdown
make CROSS_COMPILE=powerpc-linux-gnu- ARCH=powerpc uImage
Download: uImage-drm5
Re: Kernel 5.1
DRM5 boots to Firepro!
Re: Kernel 5.1
Thanks for testing! :-) Next step.
git bisect good
Output:
Bisecting: 22 revisions left to test after this (roughly 5 steps)
[48197bc564c7a1888c86024a1ba4f956e0ec2300] drm: add syncobj timeline support v9
Download: uImage-drm6
Re: Kernel 5.1
DRM6 boots to Firepro.
Re: Kernel 5.1
git bisect good
Output:
Bisecting: 11 revisions left to test after this (roughly 4 steps)
[068f304781804e208f901d8f6083189e0e28c420] drm/drm_pci.c: Use dma_zalloc_coherent
Download: uImage-drm7
Re: Kernel 5.1
DRM7 boots to SI card.
Re: Kernel 5.1
Thanks a lot for testing! :-) Next step.
git bisect bad
Output:
Bisecting: 5 revisions left to test after this (roughly 3 steps)
[e51767279f11571b112dbeaef2628968c62f90a6] drm/selftest: Refactor test-drm_plane_helper
Download: uImage-drm8
Re: Kernel 5.1
Linus Torvalds has released the Linux 5.1 stable kernel. :-)
Linux 5.1 switches the PowerPC port to use the generic swiotlb and noncoherent dma ops, and to use more generic code for the coherent direct mapping, as well.
The Cyrus patch has become smaller because of the integration of the 'fsl_pci.c' patch into the new kernel 5.1.
There was a problem with MAX_PHYSMEM_BITS. We reported this issue to the Linuxppc-dev mailing list and they fixed it.
We have activated CONFIG_SPARSEMEM for the X1000 in the kernel configuration.
There was a problem with the VLC player. It didn't play any videos anymore. We created a patch and reported it to the Linuxppc-dev mailing list. They created a new patch and integrated it into the official kernel source code. After that the VLC player works without any problems again.
There were some issues with new CF cards if they were connected to the onboard CompactFlash Card Slot from the X1000. Note: The CompactFlash (CF) card slot is wired to the CPU local bus. It is typically used to hold the Linux kernels and initial ramdisks. We solved these issues with a new pata_of_platform-v2 patch.
The initialization and use of a secondary graphics card (FirePro 2260) does not work. Bug report: https://bugs.freedesktop.org/show_bug.cgi?id=109345. We are working on a solution: http://forum.hyperion-entertainment.com ... =50#p47877
Thanks a lot to Tom, SailorMH, and Musa for testing the kernels on the X1000 and many thanks to Skateman, Kilaueabart, and Allan (acefnq) for testing the kernels on the X5000.
Download: linux-image-5.1-X1000_X5000.tar.gz
Screenshot of Lubuntu 16.04.6 LTS PowerPC with the New Moon 28.4.1 and with the final kernel 5.1:
Have a nice week! :-)
caseycullen
Re: Kernel 5.1
Post by caseycullen »
Amazing work! Thanks Christian and all others who contributed/tested!
xeno74 wrote:Hi All,
