Fienix - New PowerPC Distro
Roland wrote: There was still a dependency problem:
network-manager depends on libnm0 (= 1.20.2-1); however:
  Version of libnm0:powerpc on system is 1.14.6-2.
Please install the latest libnm0.
Download: libnm0_1.20.2-1_powerpc.deb
xeno74 wrote:Please install the latest libnm0.
Thanks, with that the whole installation advanced normally! Network is also working now :-).
Run also all the available updates for Fienix... Only some Python packages seemed to have dependency problems and were not configured.
Roland wrote: Thanks, with that the whole installation advanced normally! Network is also working now :-).
Great! :-)
@Casey
Could you please add the following packages to the Fienix repository?
caseycullen
Post by caseycullen »
Great! :-)
@Casey
Absolutely, I'll add them tonight.
Do you think these should be included in the base install?
-Casey
caseycullen
Roland wrote:Run also all the available updates for Fienix... Only some Python packages seemed to have dependency problems and were not configured.
I noticed this also. I ran "dpkg --configure -a" right after the upgrade and it fixed all the issues, so I'm having a hard time figuring out why they're happening in the first place. Try running "dpkg --configure -a" as su if you still have unconfigured packages.
-Casey
caseycullen wrote:I noticed this also. I ran "dpkg --configure -a" right after the upgrade and it fixed all the issues, so I'm having a hard time figuring out why they're happening in the first place. Try running "dpkg --configure -a" as su if you still have unconfigured packages.
-Casey
Unfortunately Mate terminal does not start anymore after the latest updates... How can I get the PangoTerm you mentioned? It was not in the Fienix depot.
caseycullen
Roland wrote:Unfortunately Mate terminal does not start anymore after the latest updates... How can I get the PangoTerm you mentioned? It was not in the Fienix depot.
Have you updated your kernel? The only one I've found to have that issue is 4.19.65. Maybe try 5.3? Do you know how to upgrade your kernel? I can give you a step-by-step if you want to try!
-Casey
caseycullen
These packages have all been added.
-Casey
I was using 4.19.53. Tested now 4.20.17, it does not have the therminal issue! I think there is not yet an initrd for 5.3, so I will use 4.20 as it works with the initrd for 4.19. I prefer to operate with the partition labels...
-Casey
Fine! IMHO network manager should definitely be in the base install as it seems to solve the network problems.
