Fienix - New PowerPC Distro
caseycullen
Post by caseycullen »
Is anyone else having this issue? I cannot replicate this issue on my everyday install or a fresh install. Does Musa have packages/libraries from other sources installed on the system?
-Casey
xeno74 wrote:Hi Casey,
Musa can‘t upgrade Arctic Fox to the version 27.9.17.
Link to the thread
Casey,
Please look in the Fienix X1000 thread.
Any way to type Japanese and maybe Korean in Fienix? For Japanese in Ubuntu I use Anthy and ibus, but neither of those seem to be available to Fienix.
Granted, there are web sites that make such languages easy to type, but having to start a browser, then copy and paste what I type, is a bit of a nuisance.
caseycullen
I'll look into adding Anthy. Thanks for the suggestion.
-Casey
kilaueabart wrote:Any way to type Japanese and maybe Korean in Fienix? For Japanese in Ubuntu I use Anthy and ibus, but neither of those seem to be available to Fienix.
caseycullen
This issue should be fixed (finally).
-Casey
FYI:
musa wrote:Hi Christian
Gramps has been added to the Fienix software repository.
When install gramp I got a error on loading the osmgps modules.
I try to install the missing dependencies I got this.
Everything else in Gramp works as far as I can see.
caseycullen
Anthy and ibus should both be available for install. Please test.
Casey
caseycullen
Pinta has been removed from the Fienix software repository for now. It depends on Mono, which has installation issues in the current version.
-Casey
xeno74 wrote:Casey,
caseycullen wrote:Pinta has been removed from the Fienix software repository for now. It depends on Mono, which has installation issues in the current version.
-Casey
Thanks a lot! :-)
caseycullen wrote:Anthy and ibus should both be available for install. Please test.
Thanks, Casey. I found and installed it today and, I think, set up the proper /.bashrc, but it doesn`t quite work yet. I can get EN or JA or あ up in the header between bluetooth and loudspeaker, but so far no matter which of those I choose I can only type English. (I have it set to あ right now. I need to type * to get (, but no Japanese.) Will have another go at it tomorrow until it gets too hot to leave my computer on again.
caseycullen
I'll look further into it. Maybe we need a compatible font?
-Casey
