Fienix - New PowerPC Distro
MichaelMerkel wrote: Thu May 07, 2020 10:19 pm exactly the same here. i tried 2 usb sticks already :-( one brand new sandisk 64gb (just bought last week) and an older one. i can access the files on the stick and copy them e.g. drom amigaos. so the stick is "working" in general.
regards...
michael
Hi Michael,
Please format the FIENIX-BOOT partition with FAT16 and copy the initial ramdisk and the kernels to this partition. I think we should use FAT16 for the FIENIX-BOOT partition in the future.
Downloads:
Hypex
Post by Hypex »
xeno74 wrote: Fri May 08, 2020 4:32 am
./arcticfox
Thanks. But it doesn't work for me. I CD'ed into the folder from a terminal. But it gave me back a command not found type of error. I used ls to check and tab completion so it certainly looked like it was there. I also tried running from desktop as admin but it did nothing. :-?
Hypex wrote: Sun May 10, 2020 6:03 pm Thanks. But it doesn't work for me. I CD'ed into the folder from a terminal. But it gave me back a command not found type of error. I used ls to check and tab completion so it certainly looked like it was there. I also tried running from desktop as admin but it did nothing. :-?
Please post the error messages. Which package did you download?
Hypex,
I can start Arctic Fox 27.10.1 with:
cd arcticfox/
fienix@Fienix:~/arcticfox$ ./arcticfox
Hypex
Post by Hypex »
xeno74 wrote: Sun May 10, 2020 7:50 pm Please post the error messages. Which package did you download?
This is some shell output:
ienix@Fienix:~$ cd '/home/fienix/Desktop/arcticfox'
fienix@Fienix:~/Desktop/arcticfox$ ./arcticfox
bash: ./arcticfox: No such file or directory
fienix@Fienix:~/Desktop/arcticfox$ ls -l
total 112984
-rw-r--r-- 1 fienix fienix      447 Mar 13 19:37 application.ini
-rwxrwxrwx 1 fienix fienix   153232 Mar 13 21:13 arcticfox
-rwxr-xr-x 1 fienix fienix   153232 Mar 13 21:13 arcticfox-bin
The package was:
http://www.xenosoft.de/arcticfox-27.10. ... 64.tar.bz2
See you have a different one. The other must be incompatible with Fienix or had some bug. This one works thanks.
One thing I have noticed, and the same happened in InterWeb, is that I am getting blank text in input boxes. Though I was going crazy when the keyboard was acting dead. But the text was white on white. They may work as a Dulux colour but it doesn't work on a computer screen! It happens with a Google search box but the built in search box is okay. Wonder if it's related to video card not being fully supported.
Hypex wrote: Mon May 11, 2020 5:47 pm See you have a different one. The other must be incompatible with Fienix or had some bug.
You tried Arctic Fox for 64-bit userlands (PPC64). Fienix has a 32-bit userland.
Hypex
Post by Hypex »
xeno74 wrote: Mon May 11, 2020 7:46 pm You tried Arctic Fox for 64-bit userlands (PPC64). Fienix has a 32-bit userland.
I got the link here somewhere. It looked like the latest. Think we need an A1XDepot. :-)
But I wonder, if the kernel is 64-bit, why Fienix running in 32-bit?
Fienix on a X5000/20 with an ATi Radeon X1650SE:
sailorMH
Post by sailorMH »
Nice and fast.
BTW, where is Your CaymanXT ? ;-)
sailorMH wrote: Sat May 30, 2020 9:33 pm Nice and fast.
In the X5000/40.
