SpiderWeb
Re: SpiderWeb
I compiled SpiderWeb 2.2.2 for Linux PPC64 today.
Download: spiderweb-2.2.2.linux-powerpc64.tar.bz2
Support thread: forums.macrumors.com
It could be, that you have to install some packages for example libffi7 for using SpiderWeb. I successfully tested it on Fedora 27 PPC64 and on openSUSE Tumbleweed 20190722 PPC64 today. If you use Debian Sid PPC64, then you need the symbolic link "libffi.so.6" to "libffi.so.7". Please create this symbolic link with the following command:
ln -s /usr/lib/powerpc64-linux-gnu/libffi.so.7 /usr/lib/powerpc64-linux-gnu/libffi.so.6
Please test the new SpiderWeb.
Re: SpiderWeb
YouTube videos in HD with ViewTube and SpiderWeb
The old version of ViewTube doesn't work with YouTube in SpiderWeb anymore. It isn't possible to install the new version with SpiderWeb. You have to install it manually.
Installation instructions:
  1. Download the ViewTube v2 script
  2. Decompress the package and copy the folder gm_scripts to /home/<your user directory>/.wicknix/spiderweb/<profile directory>
    For example:
    cp -R gm_scripts /home/amigaone/.wicknix/spiderweb/xa4ue3g6.default/
  3. Restart SpiderWeb
Re: SpiderWeb
SpiderWeb 2.2.3 has been released.
“Wicknix” wrote: SpiderWeb 2.2.3 is now available for Ubuntu 12-16, Debian 8-Sid, and Void 32-bit (glibc version). Sorry for the 6 month delay, but UXP upstream made some major changes that broke builds on older glibc. I finally tracked the problem down and resolved it locally. Download here: https://github.com/wicknix/SpiderWeb/wiki/Download and UXP upstream change log since my last build in June here: https://github.com/MoonchildProductions/UXP/releases
