ubuntu MATE 16.04.1 LTS Live USB
Re: ubuntu MATE 16.04.1 LTS Live USB
The link to your image does nothing (at least when using Odyssey) - not even an error message or an attempt to load anything.
Wicknix released the Lubuntu 16.04.6 Remix today.
Download and further information: forums.macrumors.com
Screenshot
The note above led me to the astonishing discovery that I had been using REMIX up to almost exactly one year ago! Was that when Fienix appeared on the scene?
I was equally startled to find that, with a little boot command editing, I can still almost get on. Almost, because I have no idea what my password might have been. Nevertheless I was able to find my Hyperion password from one of the places in Places, and I am writing this as a guest in REMIX! I guess I will have a go at upgrading.
Here is something weird:
^1234567890ß´
qwertzuiopü+#
QWERTZUIOPÜ*'
asdfghjklöä
ASDFGHJKLÖÄ
yxcvbnm,.-
YXCVBNM;:_
Maybe because I´m typing from guest-fmexsy´s home?
xeno74 wrote: Wed Jul 26, 2017 1:39 pm
Roland wrote: I created it with GParted, but I chose ext2... Is that important?
OK, I understand what the problem is. You copied the whole img with partitions included to an empty partition. You can't copy several partitions to an empty partition. This doesn't work.
Please look in the image with fdisk -l
fdisk -l Ubuntu-Mate_16.04.img
Disk Ubuntu-Mate_16.04.img: 7,2 GiB, 7747397632 bytes, 15131636 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x3a30f5e7
Device                 Boot    Start      End  Sectors  Size Id Type
Ubuntu-Mate_16.04.img1          2048   206847   204800  100M  6 FAT16
Ubuntu-Mate_16.04.img2        206848 14925823 14718976    7G 83 Linux
Ubuntu-Mate_16.04.img3      14925824 15130623   204800  100M 83 Linux
Do you understand what the problem is? This image was produced for a whole empty stick.
But you can mount a partition in an image and after that copy it with dd to a partition on your X5000. ;-)
Please install kpartx:
apt-get install kpartx
kpartx -l Ubuntu-Mate_16.04.img -a
loop0p1 : 0 204800 /dev/loop0 2048
loop0p2 : 0 14718976 /dev/loop0 206848
loop0p3 : 0 204800 /dev/loop0 14925824
loop0p2 is the ubuntu MATE 16.04.2 LTS root partition.
mount /dev/mapper/loop0p2 /mnt/ -o loop,ro
Another option without kpartx:
sfdisk -d Ubuntu-Mate_16.04.img
label: dos
label-id: 0x3a30f5e7
device: Ubuntu-Mate_16.04.img
unit: sectors
Ubuntu-Mate_16.04.img1 : start=        2048, size=      204800, type=6
Ubuntu-Mate_16.04.img2 : start=      206848, size=    14718976, type=83
Ubuntu-Mate_16.04.img3 : start=    14925824, size=      204800, type=83
echo $((206848 * 512)) $((14718976 * 512))
Result: 105906176 7536115712
Then:
mount -o loop,offset=105906176,sizelimit=7536115712 Ubuntu-Mate_16.04.img /mnt
Please try it.
Just for info. If you mount the partition with kpartx then it isn't possible to modify the partition. You can create, delete, or modify the files but after a remount of the partition, the file system is in the old condition again. :-(
If you want to create, delete, or modify the files then please use sfdisk instead.
Some download links are dead in this thread. I updated Julian's ubuntu MATE 16.04 USB Live img version 3 with new kernels and dtb files and uploaded it today. The alternate installer script is included in this img.
Download: X5000_Ubuntu_16.04.1_Live_USB-3c.img (md5sum: ee187684c6ea426a1558aef55b44232d)
I would recommend you to use Fienix instead of ubuntu MATE 16.04 because it is based on the latest Debian Sid and it is really faster and better supported.
U-Boot commands for booting the ubuntu MATE 16.04 Live USB system:
  1. Code: Select all
    usb reset
  2. Code: Select all
    setenv bootargs root=/dev/ramdisk file=/cdrom/preseed/ubuntu-mate.seed boot=casper rootdelay=5
  3. Code: Select all
    fatload usb 0:1 1000000 uImage-5.8 or uImage-5.7
  4. Code: Select all
    fatload usb 0:1 1c00000 cyrus-p5020.dtb or cyrus-p5040.dtb
  5. Code: Select all
    fatload usb 0:1 2000000 uRamdisk
  6. Code: Select all
    bootm 1000000 2000000 1c00000
For Radeon Southern Island cards you have to edit the xorg.conf. Please change the line Driver "radeon" to Driver "fbdev".
You can also install ubuntu MATE 16.04 with the base installer img.
Download: Amigaone_Ubuntu_16.04-Base-1.img.7z
Installation instructions: ubuntu MATE 16.04.1 LTS Live USB
Note: Some USB sticks aren't suitable for booting Linux kernels and initial ramdisks from a FAT partition. U-Boot doesn't find any storage devices on the problematic sticks.
PLEASE try another USB stick if you have problems with booting from a FAT partition.
Please test the images.
xeno74 wrote: Wed Jul 08, 2020 2:37 pm For Radeon Southern Island cards you have to edit the xorg.conf. Please change the line Driver "radeon" to Driver "fbdev".
Instructions for changing to the fbdev driver if you use Radeon SI graphics cards.
  1. Code: Select all
    usb reset
  2. Code: Select all
    setenv bootargs root=/dev/ramdisk file=/cdrom/preseed/ubuntu-mate.seed boot=casper rootdelay=5 single
  3. Code: Select all
  4. Code: Select all
  5. Code: Select all
  6. Code: Select all
  7. Code: Select all
    vi /etc/X11/xorg.conf
  8. Replace radeon with fbdev
  9. Code: Select all
    init 5
Thanks a lot Christian!
