(X)(L)ubuntu (MATE) 17.04 Zesty Zapus
vox
Re: (X)(L)ubuntu (MATE) 17.04 Zesty Zapus
Post by vox »
xeno74 wrote:Hi Vox,
From a booted USB flash drive to /dev/sdb7 for example:
Ok. If I need more clearer approach:
a) I have booted to Debian, downloaded and hopefully untarred the iso.
Can I directly DD IMG file to a empty SDB5 partition OR I need to install
it to USB (which I dont have large enough), boot from it and then rsync to SDB5
I might be demanding, but this wasnt clear enough for me.
sudo dd if=MATE_PowerPC_Remix_2017_0.5.img of=/dev/sdb7
USB isn't slow. You only need a fast USB flash drive. I would recommend you to buy the SanDisk Ultra Fit USB 3.0 Flash Drive.
I am sorry to be wrong, my USB 2.x devices are slow to boot and access many files, and even USB 3.x devices would be fast only under Linux. All of them are slow compared to SSD, and I generally consider USB booting only when nothing else works and installs of OSs to and from USB as easy way to torture people :-)
vox wrote: I have trouble unbzipping it, where can I get clean .img or tarred (.tar.bz2 doesnt work for me).
Sorry, only tar.bz2 is available currently. Please try to extract it with the following command:
tar jxvf MATE_PowerPC_Remix_2017_0.5.img.tar.bz2
Thank you very much that I havent had in past instructions.
Somewhere I found a unzip or bzip with extract switch, but it failed to work.
Also PLEASE for love of CFE and Terminal users, try shorter names, this could be MATE17v05.img
Caseycullen and Musa extracted the tar.bz2 img without any problems. Please check your system.
Nothing wrong with system, just with the humans.
Some steps like (DD/UnTar) that you take for granted arent - while we should be in time newbie Linux users are
GUI depended, not Terminal wizards. I know that we have to go to terminal to take over priviledges.
If other users succeeded in right click extract here - hmmm. I have to old Debian and your Ubuntu Live DVD
just cant handle it because he is either restricted in rw priviledges or similar.
vox wrote: Kernel 4.9 I suppose its 4.9 Final http://www.xenosoft.de/vmlinux-4.9-Amig ... 000.tar.gz and please put links to http://www.supertuxkart-amiga.de/amiga/x1000.html
There are links to the Linux kernels available on http://www.supertuxkart-amiga.de/amiga/x1000.html. Please look here for the stable longterm kernel 4.9: http://www.supertuxkart-amiga.de/amiga/kernel49.html
There is no file named STABLE, there is one FINAL and is the one linked above.
I see installs are extremely kernel sensitive, so please either always link needed kernel
in install instructions, or at the kernels sections separate user section with just stable kernels
- having them all plus alphas and betas doesnt help much.
vox wrote: LiveDVD if possible, would be best as it wouldnt require previous Linux install and essentially keeping two linuxes (see bootdvd batch and kernel on Ubuntu Remix DVD).
LiveUSB is the same. You can also create a MATE PowerPC Remix 2017 USB flash drive on Windows or on macOS. It's very easy and better as burning a DVD.
It isnt the same since it full times occupies a large stick :-)
But ..... you can try the ubuntu MATE 16.04 LTS Live DVD if you like. :-)
I have that burned and it is the DVD that boots, but ... cannot extract the newer TAR from GUI and rsync it
(or at least I cant do it), cannot install with official installer, cannot really delete partitions from its gparted
even in your alternative script sudo edit and finally alternative script looks like it copies the files, but once
restarted the system with latest 4.x kernels, system doesnt boot to MATE GUI on RadeonHD 7000 2GB
Looking at how Remix 12 DVD was built with bootdvd small batch file, couldnt be created a working
normal DVD, as it is much less hussle then any of above mentioned methods?
I know about the tinkering theory but since I use the same Ubuntu on x64 all I can say is:
a) Its is because CFE cannot really boot LILO/GRUB, Uboot can at least read some dual boot block of HDD, amigaboot.of wasnt made to look for Linux in similar fashion and CFE isnt good enough/large enough and bugfixed to at least
have some newer Uboot style menus. Choice of CFE which isnt users, has helped a lot. It could be advantage
if was done a bit better (vmlinux and amiga kickstart files could also be on card or in real ROM making able to just select what to "connect" to which partition and software changable)
b) It is because boards havent been supplied to real devel teams of distro and no real support was provided
with all respect to Amiga Linux team, support should be inbuilt in distros, like PPC Mac users dont have such "thinkering" even with similar hardware
c) So the rest is hacking. And it creates a lot of stress :)
And honest question is - is anyone working on 3D bug on PPC32/64BE Linuxes
and again, since x1000-x5000 are LE machines, could we
Which apps shall I add to the MATE PowerPC Remix 2017?
Planned:
  • Firefox 53.0
  • Thunderbird 52.0.1
I have added some new apps to the MATE PowerPC Remix 2017 this week.
Preliminary MATE PowerPC Remix 2017 0.6 changelog:
  • Some new wallpapers
  • Apache 2.4.25-3 added
  • libapache2-mod-php7.0_7.0.15-1 added
  • MySQL server 5.7.17 added (Password for the MySQL "root" user: amigaone)
  • MySQL client 5.7.17 added
  • PHP7.0-mysql added
  • phpMyAdmin 4.6.5.1-1 added
  • Claws Mail 3.14.1-3 added
  • Pidgin 2.12 added
  • Empathy 3.12.12 added
  • Cheese 3.22.1 added
  • Neverputt 1.6.0-7 added
  • GCompris 15.02-1 added
  • Tuxpaint 0.9.22-3 added
  • MPlayer2 0.24 added
  • Alex the Allegator4 1.1-7 added
  • Barbie Seahorse Adventures 1.1 added
  • Trigger Rally 0.6.5 added
Hi Christian
I'm so happy for the web server thank you so much.
And GCompris will appreciate my grandson :)
Other stuff:
Bos wars
Scummvm
Fs-uae
Warzone 2100
good weekend
musa wrote:Hi Christian
Other stuff:
Bos wars
Scummvm
Fs-uae
Warzone 2100
good weekend
Hi Musa,
I will try to add them. Thanks a lot for your suggestions!
vox
Post by vox »
Hi Musa,
My wishlist:
VLC as standard video player
Worker - file manager
DOS Box emulator - x86 emubox
Fuse, Hatari, MAME - Trio of emulators
UAE + AmiKit integration would be nice + AROS68k. As Amiga users we own legal KS and WB, they could
be copied from OS4 CD
Blender as 3D renderer and practice for AmigaOS rendering :-)
KRITA as real Photoshop replacement (better then
Inkscape and Scribus as optional graphic/DTP
Transmission as Torrent client
Phoronix Test Suite as Benchmark and Info Tools
Brasero as CD burner
Focus Writter - great and simple text editor
Asurender CD ripper - as simple CD to mp3
Home Bank - Home Budgetting
Audacious as music player, Audacity as editor
Cheese as webcam support
Some nice video editor like LightWorks (sadly DEB but x64 only)
It would be nice to have compiz and some openGL effects working on Radeon SI (Mesa problem).
New preliminary MATE PowerPC Remix 2017 0.6 changelog:
  • Many new wallpapers
  • Mesa 17.2.0-devel (git-f466683)
  • FS-UAE 2.8.0 with launcher added
  • Pidgin 2.12 added
  • Bos Wars 2.7-svn160110 added
  • ScummVM 1.9.0 added
I added ViewTube 2017.03.08 to the MATE PowerPC Remix today. It works great! I can even watch 1080p YouTube videos on my AmigaOne X1000. For Firefox 50.1, I had to create the directory plugins and I had to copy the libvlcplugin.so (browser-plugin-vlc) to this directory.
cp /usr/lib/mozilla/plugins/libvlcplugin.so /home/amigaone/Apps/firefox-50.1.0-powerpc/plugins
It works with the correct colors. Unfortunately Firefox 52.0.2 doesn't support this plugin anymore.
Good work Christian I'm looking forward to trying it.
I released the version 0.6 of the MATE PowerPC Remix 2017 for AmigaOne X5000 and AmigaOne X1000 computers today.
  • Mesa updated to 17.2.0-devel (git-f466683)
  • ubuntu MATE artwork updated to 17.10.0
  • ViewTube 2017.03.08 added
  • Lhasa 0.3.1 added (For extracting of Lha archives)
  • DOSBox 0.74 added
  • Brasero 3.12.1 added
  • Pidgin 2.12 added
  • MPlayer 1.3.0 20170413 svn37931 added
  • Kobo Deluxe 0.5.1 added
  • ClamAV 0.99.2 with ClamTk 5.24 added
  • Klavaro typing tutor 3.02 added
  • Parley vocabulary trainer 2.1.0 added
Download: MATE_PowerPC_Remix_2017_0.6.img.tar.bz2
Casey tested the version 0.6 on his X5000 today.
Link to the test thread
Screenshot of the MATE PowerPC Remix 2017 on his AmigaOne X5000:
Please test the new version 0.6.
