Fienix ssd
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
Happy thanksgiving to all . Thank you for the reply. Used the Setenv bootargs root=LABEL=FIENIX-DISK
fatload sata 0:1 1000000 uImage-5.7
fatload sata 0:1 1c00000 cyrus-p5020.dtb
fatload sata 0:1 2000000 unItrid
bootm is 1000000 2000000 1c00000.
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
Please excuse that was uInitrd thank you
Re: Fienix ssd
Tijatjj wrote: Thu Nov 25, 2021 11:31 pm Please excuse that was uInitrd thank you
Does it mean it works?
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
Hi thanks.no it is not says run -init then says sbin /init exec error attempted to kill init exit code =0x00000100
Re: Fienix ssd
Can you mount the Fienix partition on the HD from the Fienix USB stick?
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
Yes then it drops to a cli thanks
Re: Fienix ssd
Tijatjj wrote: Wed Dec 01, 2021 5:55 pm Yes then it drops to a cli thanks
What do you mean with dropping to a cli? Can you mount the Fienix partition on the hard disk?
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
hi thanks again.yes both the fat 16 and the ext4 fienix are able to be mounted .but keep getting kernal crashes as stated before /copies ok to ssd ,use gpt/then copy dd over,then resize to 125gig,it is a 1 terabyte drive ssd ? usb works fine bot not the drive ,shows its ther in gparted.
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
Using fienix-soar_3.0-2020608-net.img but it is from last year though is ther a new one.Says also get newer version of e2fsck thanks before it says not syncing
Re: Fienix ssd
Tijatjj wrote: Fri Dec 03, 2021 4:34 am Using fienix-soar_3.0-2020608-net.img but it is from last year though is ther a new one.Says also get newer version of e2fsck thanks before it says not syncing
Please post the output of “lsblk“ and “sudo blkid“ from the booted Fienix USB stick.
