HDMI audio of graphics cards
Postby Roland » Thu Feb 22, 2018 9:40 pm
I would like to test the audio side of my graphics card (Radeon HD 5450), but how to activate it? In Audio settings of Linux system it is recognized ("HDMI Cedar audio"), but cannot be activated - the only option to choose is 'OFF'! I'm sure someone here told me that the audio of graphics cards is supported in Linux....
I have also a Envy24Ht card and it can be chosen, but it still doesn't work, not even with the latest kernel versions (4.14.20, 4.15.4, 4.16.0-rc2). BTW, also the 'memory bug' which prevents from using the whole RAM with RTL 8169 is still present in all those kernel lines...:-/
Re: HDMI audio of graphics cards
Postby Spectre660 » Fri Feb 23, 2018 5:40 pm
Have to ask the basic questions to start.
Is your Monitor HDMI capable and are you connected using the HDMI port of your video card ?
Can you try with my latest kernel (4.15.5).It is working for me (Radeon RV620) .
http://dl.dropboxusercontent.com/s/woma ... ar.gz?dl=0
The Radeon HDMI sound support is built-in so no modules needed .
Just needs to be configured in Sound preferences to be Digital Stereo (HDMI) output and default device for sound output
in the Output section of Sound Preferences .
Roland wrote:I would like to test the audio side of my graphics card (Radeon HD 5450), but how to activate it? In Audio settings of Linux system it is recognized ("HDMI Cedar audio"), but cannot be activated - the only option to choose is 'OFF'! I'm sure someone here told me that the audio of graphics cards is supported in Linux....
Postby Roland » Fri Feb 23, 2018 8:27 pm
Spectre660 wrote:Have to ask the basic questions to start.
No... I will have to use a HDMI adapter with a separate audioconnector to get the sound to my monitor which has only DVDI/VGA connectors and a 3.5 mm sound plug. But I suppose the cabling does not effect directly on the available options in sound prefs...?
I downloaded it and tested... No change.
in the Output section of Sound Preferences.
The problem is that there is nothing to select... There are no settings profiles available for Radeon sound, only 'off', See below:
Postby Spectre660 » Fri Feb 23, 2018 9:01 pm
Not sure what is going wrong .
This is what I get with
dmesg | grep HDA
[ 6.537452] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/platform/ffe201000.pcie/pci1000:00/1000:00:00.0/1000:01:00.0/1000:02:02.0/1000:05:00.1/sound/card3/input7
[ 6.539467] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/platform/ffe200000.pcie/pci0000:00/0000:00:00.0/0000:01:00.1/sound/card2/input1
[ 6.539723] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/platform/ffe200000.pcie/pci0000:00/0000:00:00.0/0000:01:00.1/sound/card2/input2
[ 6.539972] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/platform/ffe200000.pcie/pci0000:00/0000:00:00.0/0000:01:00.1/sound/card2/input3
[ 6.540222] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/platform/ffe200000.pcie/pci0000:00/0000:00:00.0/0000:01:00.1/sound/card2/input4
[ 6.540532] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/platform/ffe200000.pcie/pci0000:00/0000:00:00.0/0000:01:00.1/sound/card2/input5
[ 6.540782] input: HDA ATI HDMI HDMI/DP,pcm=11 as /devices/platform/ffe200000.pcie/pci0000:00/0000:00:00.0/0000:01:00.1/sound/card2/input6
[ 6.572111] #2: HDA ATI HDMI at 0xc10040000 irq 49
[ 6.572112] #3: HDA ATI HDMI at 0xc30010000 irq 50
Postby Roland » Fri Feb 23, 2018 10:45 pm
Spectre660 wrote:Not sure what is going wrong .
dmesg | grep HDA
Here is the same from me:
[ 2.472932] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/platform/ffe200000.pcie/pci0000:00/0000:00:00.0/0000:01:00.1/sound/card1/input0
[ 2.568103] #1: HDA ATI HDMI at 0xc10020000 irq 41
Does that tell anything...?
Postby Spectre660 » Sat Feb 24, 2018 12:55 am
Apparently HDMI needs EDID info from the Monitor about both its Video and Audio capabilities to set both signals. So if it is not getting any audio capability info from your monitor it will not enable the audio.
Return to Platform: AmigaOne X5000 - Linux Only
Who is online
Users browsing this forum: No registered users and 1 guest
