NTFS Partition on RDB Disk
Postby Spectre660 » Mon Jun 19, 2017 2:41 pm
My X5000 will not boot if there is an NTFS partition on the RDB partitioned hard drive.
Hard drive also has NGFS,SFS/00,SFS/02 and EXT4 partitions
I have also tried booting with the AmigaOS4.1 FE CD copied to a USB drive .
Both booting from the USB drive and the hard drive work when the NTFS partition is removed (used LINUX to create and then delete the NTFS partition) .
Similar NTFS partition on the RDB partitioned disk drive works without problems my Sam460ex.
U-Boot 2014.04 (Oct 17 2016 - 08:22:22)
CPU0:  P5020, Version: 2.0, (0x82200020)
Core:  e5500, Version: 1.2, (0x80240012)
Clock Configuration:
       CPU0:1995 MHz, CPU1:1995 MHz,
       CCB:798  MHz,
       DDR:665  MHz (1330 MT/s data rate) (Asynchronous), LBC:49.875 MHz
       FMAN1: 498.750 MHz
       QMAN:  399 MHz
       PME:   399 MHz
L1:    D-cache 32 KiB enabled
       I-cache 32 KiB enabled
Reset Configuration Word (RCW):
       00000000: 0c540000 00000000 1e1e0000 00000000
       00000010: 44808c00 ff002000 68000000 45000000
       00000020: 00000000 00000000 00000000 0003000f
       00000030: a0000000 00000000 00000000 00000000
Board: CYRUS
36-bit Addressing
I2C:   ready
SPI:   ready
DRAM:  Initializing....using SPD
Detected UDIMM KHX1600C10D3/4G
Not enough bank(chip-select) for CS0+CS1 on controller 0, interleaving disabled!
Not enough bank(chip-select) for CS0+CS1 on controller 1, interleaving disabled!
6 GiB left unmapped
8 GiB (DDR3, 64-bit, CL=9, ECC off)
       DDR Controller Interleaving Mode: cache line
Local Bus Controller Registers
BR0     0xE0001001      OR0     0xFFF00010
BR1     0xE1001001      OR1     0xFFF00010
BR2     0x00000000      OR2     0x00000000
BR3     0x00000000      OR3     0x00000000
BR4     0x00000000      OR4     0x00000000
BR5     0x00000000      OR5     0x00000000
BR6     0x00000000      OR6     0x00000000
BR7     0x00000000      OR7     0x00000000
LBCR    0x40000000      LCRR    0x80010004
L2:    512 KiB enabled
Corenet Platform Cache: 2 MiB enabled
SERDES: bank 2 disabled
MMC:  FSL_SDHC: 0
EEPROM: NXID v0
PCIe1: Root Complex, x4 gen1, regs @ 0xfe200000
  01:00.0     - 1002:6759 - Display controller
  01:00.1     - 1002:aa90 - Multimedia device
PCIe1: Bus 00 - 01
PCIe2: Root Complex, x4 gen2, regs @ 0xfe201000
  03:00.0     - 111d:8092 - Bridge device
   04:01.0    - 111d:8092 - Bridge device
    05:00.0   - 12d8:e111 - Bridge device
     06:04.0  - 13f6:0111 - Multimedia device
     06:05.0  - 10ec:8169 - Network controller
   04:02.0    - 111d:8092 - Bridge device
   04:03.0    - 111d:8092 - Bridge device
   04:08.0    - 111d:8092 - Bridge device
   04:10.0    - 111d:8092 - Bridge device
PCIe2: Bus 02 - 0a
PCIe3: disabled
PCIe4: disabled
Looking for VGA
PINS: 0xfc000808
videoboot: Booting PCI video card bus 1, function 0, device 0
Begin BIOS POST
End BIOS POST
Setting VESA Mode
Found required VESA mode
About to set mode 279
About to get mode
Got mode 49431 (0xc117)
OK
XSize = 1024 YSize = 768 Base =0xe0000000
mmio_base = 0x80000000
bgx = 0xad55ad55 fgx = 0x0
In:    serial
Out:   serial
Err:   serial
SN: 116330051
UID: 4429431001910052907ca080a0800000
Errata: ??????
Build date: 2015/06/17 14:10:03
CRC: 1a8d9a69
SCSI:  scanning bus for devices...
Found 0 device(s).
Net:   Initializing Fman
MMC read: dev # 0, block # 1130, count 128 ...
Fman1: Uploading microcode version 106.1.0
Tuning PHY @ 3
Tuning PHY @ 7
FM1@DTSEC4 [PRIME], FM1@DTSEC5
MMC read: dev # 0, block # 1280, count 512 ... 512 blocks read: OK
MMC read: dev # 0, block # 65536, count 131072 ... 131072 blocks read: OK
USB0:   USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
USB1:   USB EHCI 1.00
scanning bus 1 for devices... 6 USB Device(s) found
SATA0 (3 Gbps)
       SATA1 (No RDY)
Found 0 device(s).
resetting USB...
USB0:   USB EHCI 1.00
USB1:   USB EHCI 1.00
       scanning usb for storage devices... 1 Storage Device(s) found
## Starting application at 0x00200000 ...
Loading finished             [########################################] 100 %
About to call loader entry at 0x7BD02020
[ColdStart] ExecSG
[ColdStart] Copyright (c) 2002-2015 Thomas and Hans-Joerg Frieden
[ColdStart] exec 53.89 (28.11.2016)
[ColdStart] Kernel commandline: serial munge debuglevel=1
[ColdStart] Debug level: 1
[mem_enable_munge] *** Warning: Memory munging enabled for malloc/free emulation
[HAL_InitCPU] CPU: e5500 1.2
[rebuild_segment_info] Section map:
[rebuild_segment_info] 0: Partially executable
[rebuild_segment_info] 1: Not executable
[rebuild_segment_info] 2: Not executable
[rebuild_segment_info] 3: Not executable
[rebuild_segment_info] 4: Not executable
[rebuild_segment_info] 5: Not executable
[rebuild_segment_info] 6: Not executable
[rebuild_segment_info] 7: Executable
[rebuild_segment_info] 8: Not executable
[rebuild_segment_info] 9: Not executable
[rebuild_segment_info] 10: Not executable
[rebuild_segment_info] 11: Not executable
[rebuild_segment_info] 12: Not executable
[rebuild_segment_info] 13: Not executable
[rebuild_segment_info] 14: Not executable
[rebuild_segment_info] 15: Not executable
[HAL_SetupMemoryEnvironment] Stage 1 memory setup
[InternalMapMemory] Trying to map 0x01000000 to 0x01000000, length 0x800000 with attrs 0x00000044
[InternalMapMemory] Trying to map 0x02000000 to 0x02000000, length 0x130000 with attrs 0x000000C0
[InternalMapMemory] Trying to map 0x02130000 to 0x02130000, length 0x25FFFF with attrs 0x00000080
[InternalMapMemory] Trying to map 0x01800000 to 0x01800000, length 0x7FFFFF with attrs 0x000000C0
[InternalMapMemory] Trying to map 0x00000000 to 0x00000000, length 0x3000 with attrs 0x00000080
[HAL_SetupMemoryEnvironment] Enabling MMU
[HAL_SetupMemoryEnvironment] Stage 1 complete
[HAL_BookECacheControl] old registers: l1csr0 = 0x00010001, l1csr1 = 0x00010001, l2csr0 = 0x00010000, cpccsr0 = 0xC0000000
[HAL_BookECacheControl] new registers: l1csr0 = 0x00010001, l1csr1 = 0x00010001, l2csr0 = 0x80010000, cpccsr0 = 0xC0000000
[ColdStart] Stored checksum = 0x00000000
[ColdStart] Computed checksum = 0x00000000
[radix_tree_init] Max Key for 0 = 0x00000000
[radix_tree_init] Max Key for 1 = 0x0000003F
[radix_tree_init] Max Key for 2 = 0x00000FFF
[radix_tree_init] Max Key for 3 = 0x0003FFFF
[radix_tree_init] Max Key for 4 = 0x00FFFFFF
[radix_tree_init] Max Key for 5 = 0x3FFFFFFF
[mark_pages] Marking pages from 0x00000000 to 0x00002FFF as used
[mark_pages] Marking pages from 0x01000000 to 0x0238FFFF as used
[HAL_AddAllocatorPages] Adding page pool 0x02148C80, BaseAddress = 0x0000000000000000, TopAddress = 0x000000007FFFFFFF
[HAL_AddAllocatorPages] Free pages in pool = 519279
[HAL_AddAllocatorPages] Total pages in pool = 524288
[rmap_init] QCacheMax = 0
[rmap_init] Creating 0 caches
[HAL_CalibrateTimer] Timebase clock select is Platform clock/32
[HAL_CalibrateTimer] U-Boot bus frequency reported as 798000000
[rmap_init] QCacheMax = 32767
[rmap_init] Creating 7 caches
[rmap_init] Creating QCache 00 for 0x022DBD08
[rmap_init] Creating QCache 01 for 0x022DBD08
[rmap_init] Creating QCache 02 for 0x022DBD08
[rmap_init] Creating QCache 03 for 0x022DBD08
[rmap_init] Creating QCache 04 for 0x022DBD08
[rmap_init] Creating QCache 05 for 0x022DBD08
[rmap_init] Creating QCache 06 for 0x022DBD08
[default_init] Adding Alloc/Free emulation to area executable heap (0x022DBC20)
[ColdStart] Added executable range 0x70000000 - 0x80000000
[rmap_init] Creating QCache 00 for 0x022DF908
[rmap_init] Creating QCache 01 for 0x022DF908
[rmap_init] Creating QCache 02 for 0x022DF908
[rmap_init] Creating QCache 03 for 0x022DF908
[rmap_init] Creating QCache 04 for 0x022DF908
[rmap_init] Creating QCache 05 for 0x022DF908
[rmap_init] Creating QCache 06 for 0x022DF908
[default_init] Adding Alloc/Free emulation to area primary heap (0x022DF820)
[mem_init] Initializing emu ctrl 0x022E2310 for VMA 0x022DF820
[ColdStart] Added virtual range 0x10000000 - 0x70000000
[ColdStart] Using as resident memory area
[HAL_SetupMemoryEnvironment2] Kernel data segment VMArea created, vma = 0x022E3420
[HAL_SetupMemoryEnvironment2] Kernel text segment VMArea created, vma = 0x022E7020
[HAL_SetupMemoryEnvironment2] Custom chip interceptor VMArea created, vma = 0x022EAC20
[HAL_SetupMemoryEnvironment2] Custom chip CIA interceptor VMArea created, vma = 0x022EE820
[HAL_SetupMemoryEnvironment2] ROM space interceptor VMArea created, vma = 0x022F2420
[HAL_SetupMemoryEnvironment2] Core Configuration Space VMArea created, vma = 0x022F6020
[init_kernel_heap] DEBUG: Would get address space for kernel heap at 0xEE000000
[init_kernel_heap] Added kernel heap (Pri -127, vma = 0x022F9C20)
[res_init] Initialising resident memory system
[ColdStart] Computed checksum after res_init: 0x70003000
[_impl_InitCode] Initializing module flush.resident 53.1 (1.2.2010)
 [_impl_InitCode] Initializing module expansion.library 53.1 (16.6.2008)
 [_impl_InitCode] Initializing module post reset code of timer.device 53.2 (17.9.2014)
 [_impl_InitCode] Initializing module exec 53.89 (28.11.2016)
 [HAL_mpic_Init] HAL_MPIC_WHOAMI = 0
[HAL_SetupMachineEvents] Installing Critical Interrupt Exception at 0x00000100
[HAL_SetupMachineEvents] Installing Machine Check Exception at 0x00000200
[HAL_SetupMachineEvents] Installing Data Storage Exception at 0x00000300
[HAL_SetupMachineEvents] Installing Instruction Storage Exception at 0x00000400
[HAL_SetupMachineEvents] Installing External Interrupt Exception at 0x00000500
[HAL_SetupMachineEvents] Installing Alignment Exception at 0x00000600
[HAL_SetupMachineEvents] Installing Program Exception at 0x00000700
[HAL_SetupMachineEvents] Installing FPU Unavailable Exception at 0x00000800
[HAL_SetupMachineEvents] Installing System Call Exception at 0x00000C00
[HAL_SetupMachineEvents] Installing Fixed Interval and Watchdog Timers Exception at 0x00001000
[HAL_SetupMachineEvents] Installing Debug Exception at 0x00002000
[HAL_SetupMachineEvents] Installing Performance Monitor Exception at 0x00002100
[HAL_SetupMachineEvents] Installing Doorbell Interrupt Exception at 0x00002200
[HAL_SetupMachineEvents] Installing Doorbell Critical Interrupt Exception at 0x00002300
[HAL_SetupMachineEvents] Installing Generic Exception at 0x00002400
[HAL_SetupMachineEvents] TCR: 0x00000000, setting to 0x04000000
[HAL_SetupWatchdog] Setting up watchdog timer
[HAL_SetupWatchdog] For reference: default quantum is 0x0013069B
[HAL_SetupWatchdog] Watchdog selected bit 43 for time period
[HAL_SetupWatchdog] Done, tcr set up as 0xCC140000
[page_buddyalloc_convert_from_boot] Converting boot allocator to buddy allocator
[page_buddyalloc_convert] Creating new allocator from pool with BaseAddress = 0x0000000000000000 and TopAddress 0x000000007FFFFFFF
[page_buddyalloc_convert] Pool has 524288 total pages
[page_buddyalloc_init] Creating new buddy allocator with BaseAddress = 0x0000000000000000 and TopAddress 0x000000007FFFFFFF
[page_buddyalloc_convert] Starting conversion from 0 to 524288
[page_buddyalloc_convert] Done
[page_buddyalloc_convert_from_boot] Done converting
[StartExec] Page backend has 524287 pages total, 519139 available
[HAL_FillCPUInfo] CPU: e5500 1.2
[StartExec] Let the good times roll !!! Multitasking enabled
[_impl_InitCode] Initializing module Shutdown Handler 53.1 (07.10.2015)
 [_impl_InitCode] Initializing module diag init
 [InternalMapMemory] Trying to map 0xF8000000 to 0xF8000000, length 0x10000 with attrs 0xFF80008A
[pcie_setup] PEX0: itar = 0x00FFE000, iwbar = 0x00000000, iwbear = 0x00000000, iwar = 0x00E44017
[pcie_setup] Outbound windows:
[pcie_dump_atmu_ob] 0: otar = 0x00000000, otear = 0x00000000, owbar = 0x00000000, owar = 0x80044023
[pcie_dump_atmu_ob] 1: otar = 0x000E0000, otear = 0x00000000, owbar = 0x00C00000, owar = 0x8004401C
[pcie_dump_atmu_ob] 2: otar = 0x00000000, otear = 0x00000000, owbar = 0x00FF8000, owar = 0x8008800F
[pcie_dump_atmu_ob] 3: otar = 0x00000000, otear = 0x00000000, owbar = 0x00000000, owar = 0x00000000
[pcie_setup] Inbound windows:
[pcie_dump_atmu_ib] 0: itar = 0x00000000, iwbar = 0x00000000, iwbear = 0x00000000, iwar = 0x20F44023
[pcie_dump_atmu_ib] 1: itar = 0x00000000, iwbar = 0x01000000, iwbear = 0x00000000, iwar = 0x00000000
[pcie_dump_atmu_ib] 2: itar = 0x00000000, iwbar = 0x00000000, iwbear = 0x00000000, iwar = 0xA0F5501F
[pcie_dump_atmu_ib] 3: itar = 0x00FFE000, iwbar = 0x00000000, iwbear = 0x00000000, iwar = 0x80E44017
[InternalMapMemory] Trying to map 0xF8010000 to 0xF8010000, length 0x10000 with attrs 0xFF80108A
[pcie_setup] PEX1: itar = 0x00FFE000, iwbar = 0x00000000, iwbear = 0x00000000, iwar = 0x00E44017
[pcie_dump_atmu_ob] 1: otar = 0x000E0000, otear = 0x00000000, owbar = 0x00C20000, owar = 0x8004401C
[pcie_dump_atmu_ob] 2: otar = 0x00000000, otear = 0x00000000, owbar = 0x00FF8010, owar = 0x8008800F
[InternalMapMemory] Trying to map 0x80000000 to 0x00000000, length 0x10000000 with attrs 0xC0000086
[InternalMapMemory] Trying to map 0x90000000 to 0x10000000, length 0x20000 with attrs 0xC000008E
[InternalMapMemory] Trying to map 0x90020000 to 0x10020000, length 0x4000 with attrs 0xC000008E
[InternalMapMemory] Trying to map 0xA0000000 to 0x20000000, length 0x100 with attrs 0xC200008E
[_impl_InitCode] Initializing module newlib.library 53.36 (17.9.2016)
 [_impl_InitCode] Initializing module utility.library 54.1 (30.3.2014)
 [_impl_InitCode] Initializing module uhci_early_stop 53.1 (21.9.2012)
 [_impl_InitCode] Initializing module idle.task 53.1 (9.2.2010)
 [_impl_InitCode] Initializing module emusetup hack 53.1
 [___emusetup] Trying to find radeon card
[___emusetup] Found one
[_impl_InitCode] Initializing module emulator.resource 53.1
 [_impl_InitCode] Initializing module memdebug.resident 52.2 (19.2.2007)
 [_impl_InitCode] Initializing module async_serial_debug.resident 53.1 (23.6.2016)
 [_impl_InitCode] Initializing module FileSystem.resource 53.1 (12.2.2011)
 [_impl_InitCode] Initializing module CDFileSystem 53.4 (20.9.2012)
 [_impl_InitCode] Initializing module i2c.resource 53.2 (3.9.2015)
 [_impl_InitCode] Initializing module battclock.resource 54.1 (1.5.2016)
 [_impl_InitCode] Initializing module timer.device 53.2 (17.9.2014)
 [_impl_InitCode] Initializing module $VER: ohci_early_stop [_impl_InitCode] Initializing module $VER: ehci_early_stop [EHCI] *usbbase=FE210100
[EHCI] *usbbase=FE211100
[_impl_InitCode] Initializing module graphics.library 54.226 (13.9.2016)
 graphics.library P50XX optimizations enabled
RadeonHD (2): Graphics card name is: Radeon HD 6570
RadeonHD (2): Identified the chipset as: TURKS
RadeonHD (2):   If - and only if - your card does not work or does not work optimally
        please submit a bug report at:
        http://www.amigadeveloper.com/bugreports
        Remember to include the driver version, and the following card details:
        0x6759:0x1B0A:0x9091: <name of board>
        and *please* describe the problems you are seeing in detail.
[_mmu_RemapMemory] Trying to remap 0x80000000 to 0x00000000, length 131072 with attrs 0xC00000C6
[_mmu_RemapMemory] Trying to remap 0x80000000 to 0x00000000, length 131072 with attrs 0xC0000086
RadeonHD.chip (0): Object: ID: 310C name: HDMI_TYPE_A type: 3 id: C
RadeonHD.chip (0): Object: ID: 3101 name: SINGLE_LINK_DVI_I type: 3 id: 1
RadeonHD.chip (0):
RadeonHD.chip (0): --------------------------------------
RadeonHD.chip (0): CONNECTOR TABLE:
RadeonHD.chip (0):
RadeonHD.chip (0): Connector[0] HDMI 1:
RadeonHD.chip (0):   Type: RHD_CONNECTOR_HDMI_A
RadeonHD.chip (0):   DDC bus: RHD I2C line 2
RadeonHD.chip (0):   HPD: RHD_HPD_3 (monitor connected)
RadeonHD.chip (0):   Outputs:
RadeonHD.chip (0):     Output AtomOutputUniphyE:
RadeonHD.chip (0):       Type: RHD_OUTPUT_UNIPHYE
RadeonHD.chip (0):       Device Type: atomDFP1
RadeonHD.chip (0):              Device Record: Type: atomDFP1, Connector Type: RHD_CONNECTOR_HDMI_A, ConnectorID: 0xC, EncoderID: 0x21
RadeonHD.chip (0):
RadeonHD.chip (0): Connector[1] DVI-I 1:
RadeonHD.chip (0):   Type: RHD_CONNECTOR_DVI_SINGLE
RadeonHD.chip (0):   DDC bus: RHD I2C line 3
RadeonHD.chip (0):   HPD: RHD_HPD_0 (monitor not connected)
RadeonHD.chip (0):     Output AtomOutputUniphyC:
RadeonHD.chip (0):       Type: RHD_OUTPUT_UNIPHYC
RadeonHD.chip (0):       Device Type: atomDFP2
RadeonHD.chip (0):              Device Record: Type: atomDFP2, Connector Type: RHD_CONNECTOR_DVI_SINGLE, ConnectorID: 0x1, EncoderID: 0x20
RadeonHD.chip (0):     Output AtomOutputDACA:
RadeonHD.chip (0):       Type: RHD_OUTPUT_DACA
RadeonHD.chip (0):       Device Type: atomCRT1
RadeonHD.chip (0):              Device Record: Type: atomCRT1, Connector Type: RHD_CONNECTOR_DVI_SINGLE, ConnectorID: 0x1, EncoderID: 0x15
RadeonHD.chip (0):
RadeonHD.chip (0):
RadeonHD.chip (0): RadeonHD card successfully opened
0000: 00 FF FF FF FF FF FF 00 5A 63 2E DE 01 01 01 01  ........Zc......
0010: 18 1A 01 03 80 34 1D 78 2E 2C C5 A4 56 50 A1 28  .....4.x.,..VP.(
0020: 0F 50 54 BF EF 80 B3 00 A9 40 A9 C0 95 00 90 40  .PT......@.....@
0030: 81 80 81 40 81 00 02 3A 80 18 71 38 2D 40 58 2C  ...@...:..q8-@X,
0040: 45 00 09 25 21 00 00 1E 00 00 00 FF 00 54 56 54  E..%!........TVT
0050: 31 36 32 34 30 30 30 37 38 0A 00 00 00 FD 00 32  162400078......2
0060: 4B 0F 52 13 00 0A 20 20 20 20 20 20 00 00 00 FC  K.R.............
0070: 00 56 58 32 34 35 32 20 53 65 72 69 65 73 01 4C  .VX2452.Series.L
0080: 02 03 28 F1 55 90 05 04 03 02 07 06 08 09 0E 0F  ..(.U...........
0090: 1F 14 13 12 11 15 16 1D 1E 01 23 09 7F 07 83 01  ..........#.....
00A0: 00 00 65 03 0C 00 10 00 02 3A 80 18 71 38 2D 40  ..e......:..q8-@
00B0: 58 2C 45 00 09 25 21 00 00 1E 01 1D 80 18 71 1C  X,E..%!.......q.
00C0: 16 20 58 2C 25 00 09 25 21 00 00 9E 01 1D 00 72  ..X,%..%!......r
00D0: 51 D0 1E 20 6E 28 55 00 09 25 21 00 00 1E 8C 0A  Q...n(U..%!.....
00E0: D0 8A 20 E0 2D 10 10 3E 96 00 09 25 21 00 00 18  ....-..>...%!...
00F0: 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00  ................
Video Data Block
SVD: ID 16 (native)
Audio Data Block
SAD: Format=1 NumChannels=2
Speaker Allocation Data Block
Vendor Specific Data Block
[_impl_InitCode] Initializing module bootsd.resource 54.5 (26.10.2016)
 [InternalMapMemory] Trying to map 0xFE114000 to 0xFE114000, length 0x1000000 with attrs 0x0000008A
[_impl_InitCode] Initializing module graphicsPPC_PIV_support 52.1 (7.12.2006)
 [_impl_InitCode] Initializing module newmemory.resource 52.2 [_impl_InitCode] Initializing module pager.resource 52.1 [_impl_InitCode] Initializing module nonvolatile.library 54.2 (26.08.2015)
 [_impl_InitCode] Initializing module keymap.library 53.9 (4.5.2014)
 [_impl_InitCode] Initializing module keyboard.device 53.12 (26.4.2015) [_impl_InitCode] Initializing module reset handler of timer.device 53.2 (17.9.2014)
 [_impl_InitCode] Initializing module input.device 53.5 (16.2.2014)
 [_impl_InitCode] Initializing module ramdrive.device 52.6 (7.5.2008)
 [_impl_InitCode] Initializing module ramdrive boot unit [_impl_InitCode] Initializing module intuition.library 54.26 (21.6.2016)
 [_impl_InitCode] Initializing module <unknown module>
 [_impl_InitCode] Initializing module NGFileSystem 54.34 (9.11.2016) Interim X-5000 version
 [_impl_InitCode] Initializing module console.device 53.99 (5.05.2016)
 [_impl_InitCode] Initializing module acpi.resource 53.4 (11.9.2015)
 [_impl_InitCode] Initializing module elf.library 53.27 (18.10.2016)
 [_impl_InitCode] Initializing module hunk.library 53.4 (2.5.2011)
 [_impl_InitCode] Initializing module usbresource.library 53.14 (15.8.2015)
 [_impl_InitCode] Initializing module xena.resource.kmod 53.2 (8.10.2015)
 [_impl_InitCode] Initializing module sii3112ide.device 53.20 (24.9.2014)
[sii3112ide/dev_init] Nothing started, bailing out
[_impl_InitCode] Initializing module sii3114ide.device 53.20 (24.9.2014)
[sii3114ide/dev_init] Nothing started, bailing out
[_impl_InitCode] Initializing module sii3512ide.device 53.20 (24.9.2014)
[sii3512ide/dev_init] Nothing started, bailing out
[_impl_InitCode] Initializing module sii0680ide.device 53.20 (24.9.2014)
[sii0680ide/dev_init] Nothing started, bailing out
[_impl_InitCode] Initializing module lsi53c8xx.device 53.20 (24.9.2014)
[lsi53c8xx/dev_init] Nothing started, bailing out
[_impl_InitCode] Initializing module it8212ide.device 53.20 (24.9.2014)
[it8212ide/dev_init] Nothing started, bailing out
[_impl_InitCode] Initializing module syscheck 53.1 (22.6.2016)
 [_impl_InitCode] Initializing module romboot 52.3 (11.7.2007)
 [_impl_InitCode] Initializing module diskboot 53.11 (19.04.2014)
 [_impl_InitCode] Initializing module mounter.library 53.19 (13.11.2016)
 [_impl_InitCode] Initializing module mediaboot 53.19 (13.11.2016)
 [mediaboot] Diskboot is present. Skip mounting static devices.
[_impl_InitCode] Initializing module bootmouse 53.3 (20.1.2016)
 [_impl_InitCode] Initializing module bootkeyboard.usbfd 52.3 (1.4.2007) [_impl_InitCode] Initializing module hub 53.10 (23.9.2012)
 [_impl_InitCode] Initializing module massstorage.usbfd 53.83 (27.11.2016)
 fdmain.c/29 Task "exec.task" [fdmain_init()] =>enter
fdmain.c/32 Task "exec.task" [fdmain_init()] =>leave
fdmain.c/49 Task "exec.task" [fdmain_register()] =>MyFDKey=0x6FF0B7E0
[_impl_InitCode] Initializing module uhci.usbhcd 53.13 (21.9.2012)
 [_impl_InitCode] Initializing module ohci.usbhcd 53.21 (21.11.2015)
 [_impl_InitCode] Initializing module ehci.usbhcd 53.24 (27.11.2016)
 [EHCI] Found P50xx CPU
[_impl_InitCode] Initializing module $VER: p5020sata.device launch launch_dev() enter
p5020sata.device.kmod 54.69
create_sata_port(0)
0:task_entry(su=0x6FFB2680)
0:CHBA = 0x2400000 (virtual@0x6FC31000)
6ata0: SATA max UDMA/133 irq 84
6ata0: hard resetting link
6ata0: Signature Update detected @ 500 msecs
6ata0: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
4ata0.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
0:ata_eh_handle_dev_fail(dev=0x6FE3C9B0, err=-5)
6ata0.00: ATA-9: ST2000DX001-1NS164, CC41, max UDMA/133
6ata0.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 16/32)
6ata0.00: configured for UDMA/133
0:handle_io(su=0x6FFB2680) ENTER
started p5020sata.device Port 0 interrupt=84
create_sata_port(1)
1:task_entry(su=0x6FEAE000)
1:CHBA = 0x400000 (virtual@0x6FA15000)
6ata1: SATA max UDMA/133 irq 85
6ata1: hard resetting link
4ata1: ata_wait_register timed out timeout=500 ms
4ata1: now=6124 deadline=6124
4ata1: No Device OR PHYRDY change,Hstatus = 0xa0000000
6ata1: SATA link down (SStatus 0 SControl 300)
1:handle_io(su=0x6FEAE000) ENTER
started p5020sata.device Port 1 interrupt=85
1:port_is_ready: devclass=0
unit 0 announced
dev_open(unitNumber=0) [Mounter Task]
0:HD_SCSICMD: class=1 CmdCode=0x43 CmdLength=10 ignored
DH1
DH7
launch_dev() exit
[_impl_InitCode] Initializing module usbsys.device 53.14 (15.8.2015)
 [_impl_InitCode] Initializing module $VER: USB boot point delay fdmain.c/76 Task "massstorage.usbfd" [fdmain()] =>enter
fdmain.c/98 Task "massstorage.usbfd" [fdmain()] =>Waiting for the attachment message 0x6F954700 to be replied
USB0
fdmain.c/101 Task "massstorage.usbfd" [fdmain()] =>Attachment message 0x6F954700 was replied
fdmain.c/128 Task "massstorage.usbfd" [fdmain()] =>leave
[_impl_InitCode] Initializing module bootmenu.kmod 53.12 (22.6.2016)
 [_impl_InitCode] Initializing module alert.hook
 [_impl_InitCode] Initializing module strap 53.4 (20.9.2012)
[DOS] NOTE: Kernel debug level detected as 1
dev_open(unitNumber=0) [DH1/NGFileSystem 54.34 ]
dev_open(unitNumber=0) [DH7/NGFileSystem 54.34 ]
 [_impl_InitCode] Initializing module reaper 53.1 (16.6.2008)
 [_impl_InitCode] Initializing module env-handler 54.5 (16.8.2014)
 [_impl_InitCode] Initializing module petunia 53.6 (13.11.2013)
 [_impl_InitCode] Initializing module appdir-handler-in-dos 53.158 (21.9.2015)
 [_impl_InitCode] Initializing module ramlib.kmod 53.19 (30.6.2011)
 [_impl_InitCode] Initializing module modules 52.2 [_impl_InitCode] Initializing module ram-handler 53.172 (21.9.2015)
 [HAL_IceColdReboot] Goodbye!
[HAL_BookECacheControl] old registers: l1csr0 = 0x00010001, l1csr1 = 0x00010001, l2csr0 = 0x80010000, cpccsr0 = 0xC0000000
Re: NTFS Partition on RDB Disk
Postby tonyw » Tue Jun 20, 2017 3:11 pm
Does toggling the "AutoMount" flag make a difference?
I ask because on the Sam460 the partitions are mounted by diskboot, but on the X5k they are mounted by the device drivers, using mounter.library.
Postby Spectre660 » Tue Jun 20, 2017 3:30 pm
Will try at some point .
Will have to remove the hard drive and boot with the AmigaOS4.1FE USB thumb drive then connect the hard drive via usb to toggle.
Then reconnect the hard drive and try to boot.
tonyw wrote:Does toggling the "AutoMount" flag make a difference?
Postby Spectre660 » Tue Jun 20, 2017 5:31 pm
@tonyw
Done.
unticking the automount flag for the partition solves the problem.
can mount the partition using a mountlist file in DODrivers .
Spectre660 wrote:Will try at some point .
Postby tonyw » Thu Jun 22, 2017 2:56 am
OK, that sounds like a work-around, then. I'll alert the author to your problem.
[Bug #9880]
Postby Spectre660 » Thu Jun 22, 2017 1:23 pm
Thanks .
tonyw wrote:OK, that sounds like a work-around, then. I'll alert the author to your problem.
[Bug #9880]
Return to Platform: AmigaOne X5000
Who is online
Users browsing this forum: No registered users and 1 guest
