Connecting a "Competion Pro USB Joystick"...
Postby marley » Sat May 06, 2017 1:25 pm
Hi Guys
Can any one tell me if i can connect a competion pro USB joystick to my AMIGA 5000 so i can play some classic games?
ive tryed a joypad which is USB and that dont work, ;-(
any ideas, i seen a classic joystick connector on the back of my motherboard/case and pluged a standard joystick in but thet dont work either only i got over 10,000 games to play especially when its raining here in Cornwall
marley
Re: Connecting a "Competion Pro USB Joystick"...
Postby Radek » Sat May 06, 2017 3:25 pm
Of course you can use usb controllers, you can even use classic controllers with adapter like this.
But not through DB9 connector on the back, it's only for capturing serial logs. Regarding usb joypads/sticks. You need to go to Amigainput preferences and make
sure it's been recognized. It should be plug'n'play, however sometimes it's not a case.
Radek
Postby Raziel » Sat May 13, 2017 5:02 pm
marley wrote:Hi Guys
I learned that AmigaInput is not "Plug and Play" as you may know it from other platforms.
I had to start AmigaInput, THEN plug the device in to get it recognized, THEN set it up in AmigaInput and only THEN was i able to use it.
If slaughterhouses had glass walls, everyone would be a vegetarian. ~ Sir Paul McCartney
Did everything just taste purple for a second? ~ Philip J. Fry
Ain't got no cash, ain't got no style, ladies vomit when I smile. ~ Dr. John Zoidberg
Postby IamSONIC » Wed May 31, 2017 11:31 pm
@marley
I have a Speed-Link Competition Pro connected to the AmigaOne X5000 and it works flawlessly
IamSONIC
Postby daveyw » Wed Jun 21, 2017 7:36 am
I have a Logitech F310. The buttons work OK, but the sticks do nothing. How do I configure the sticks to act as joysticks?
daveyw
Return to Platform: AmigaOne X5000
Who is online
Users browsing this forum: No registered users and 1 guest
