X1k No on-board sound. (Linux)
Postby mechanic » Tue May 22, 2012 5:12 pm
I have been using the PCI card for sound as it works for Amiga and Linux.
A few days ago I tried the on-board sound with Linux using the supplied
vmlinux39 kernel and modules. No sound from the on-board connectors.
My speakers will give a 'thump' when power turned on and another when the
kernel is booting, but nothing after that.
If I select to use the HDA sound, only the PCI card still produces sound.
I tried removing the PCI card with the result of no sound at all and
Timidity would not even startup.
Suggestions, tips, questions, try, ..........HELP!
Some log and other info below.
Hidden Text - Click to Show :
/proc/asound/cards
0 [CMI8738]: CMI8738-SWIEC - C-Media CMI8738
C-Media CMI8738 (model 33) at 0x3100, irq 217
1 [HDMI]: HDA-Intel - HDA ATI HDMI
HDA ATI HDMI at 0xa0030000 irq 49
2 [SB]: HDA-Intel - HDA ATI SB
HDA ATI SB at 0xa0200000 irq 212
/proc/asound/pcm
00-00: CMI8738-SWIEC : C-Media PCI DAC/ADC : playback 1 : capture 1
00-01: CMI8738-SWIEC : C-Media PCI 2nd DAC : playback 1
00-02: CMI8738-SWIEC : C-Media PCI IEC958 : playback 1 : capture 1
01-03: HDMI 0 : HDMI 0 : playback 1
02-00: STAC92xx Analog : STAC92xx Analog : playback 1 : capture 3
02-01: STAC92xx Digital : STAC92xx Digital : playback 1 : capture 1
00:00.0 Host bridge: PA Semi, Inc PWRficient Host Bridge (rev 12)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 86
Capabilities: [40] Vendor Specific Information: Len=18 <?>
00:01.0 Memory controller: PA Semi, Inc PWRficient L2 Cache (rev 11)
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 82
00:03.0 PIC: PA Semi, Inc PWRficient System/Debug Controller (rev 13) (prog-if 80)
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 84
00:04.0 RAM memory: PA Semi, Inc PWRficient DDR2 Memory Controller (rev 11)
Interrupt: pin A routed to IRQ 88
Kernel driver in use: pasemi_edac
00:05.0 RAM memory: PA Semi, Inc PWRficient DDR2 Memory Controller (rev 11)
Interrupt: pin A routed to IRQ 90
00:08.0 Power PC: PA Semi, Inc PA6T Core (rev 12)
Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
00:09.0 Power PC: PA Semi, Inc PA6T Core (rev 12)
00:10.0 PCI bridge: PA Semi, Inc PWRficient PCI-Express Port (rev 11) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: 90000000-a00fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Express (v1) Root Port (Slot+), MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 7, Latency L0s <64ns, L1 <1us
ExtTag+ RBE+ FLReset-
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x16, ASPM L0s L1, Latency L0 <64ns, L1 <1us
ClockPM- Surprise+ LLActRep+ BwNot-
LnkCtl: ASPM Disabled; RCB 128 bytes Disabled- Retrain- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk- DLActive+ BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
Changed: MRL- PresDet- LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
Capabilities: [70] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100 v1] Root Complex Link
Desc: PortNumber=01 ComponentID=01 EltType=Config
Link0: Desc: TargetPort=00 TargetComponent=01 AssocRCRB+ LinkType=MemMapped LinkValid-
Addr: 00000000e0007100
Capabilities: [120 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed+ WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
VC1: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Ctrl: Enable- ID=0 ArbSelect=Fixed TC/VC=00
Capabilities: [150 v1] Vendor Specific Information: ID=0001 Rev=1 Len=02c <?>
Capabilities: [200 v1] Vendor Specific Information: ID=0003 Rev=1 Len=088 <?>
Kernel driver in use: pcieport
00:10.1 PCI bridge: PA Semi, Inc PWRficient PCI-Express Port (rev 11) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Capabilities: [40] Express (v1) Root Port (Slot-), MSI 00
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <64ns, L1 <1us
LnkSta: Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
Desc: PortNumber=02 ComponentID=01 EltType=Config
Status: InProgress-
00:10.2 PCI bridge: PA Semi, Inc PWRficient PCI-Express Port (rev 11) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
LnkCap: Port #2, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <64ns, L1 <1us
Desc: PortNumber=03 ComponentID=01 EltType=Config
Status: InProgress-
00:10.3 PCI bridge: PA Semi, Inc PWRficient PCI-Express Port (rev 11) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
LnkCap: Port #3, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <64ns, L1 <1us
Desc: PortNumber=04 ComponentID=01 EltType=Config
Status: InProgress-
00:11.0 PCI bridge: PA Semi, Inc PWRficient PCI-Express Port (rev 11) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=05, subordinate=06, sec-latency=0
I/O behind bridge: 00000000-00003fff
Memory behind bridge: a0100000-a03fffff
LnkCap: Port #4, Speed 2.5GT/s, Width x4, ASPM L0s L1, Latency L0 <64ns, L1 <1us
LnkSta: Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk- DLActive+ BWMgmt- ABWMgmt-
Desc: PortNumber=05 ComponentID=01 EltType=Config
Status: InProgress-
00:11.1 PCI bridge: PA Semi, Inc PWRficient PCI-Express Port (rev 11) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
LnkCap: Port #5, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <64ns, L1 <1us
Changed: MRL- PresDet- LinkState-
Desc: PortNumber=06 ComponentID=01 EltType=Config
Status: InProgress-
00:11.2 PCI bridge: PA Semi, Inc PWRficient PCI-Express Port (rev 11) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
LnkCap: Port #6, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <64ns, L1 <1us
Desc: PortNumber=07 ComponentID=01 EltType=Config
Status: InProgress-
00:11.3 PCI bridge: PA Semi, Inc PWRficient PCI-Express Port (rev 11) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
LnkCap: Port #7, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <64ns, L1 <1us
Desc: PortNumber=08 ComponentID=01 EltType=Config
Status: InProgress-
00:14.0 Ethernet controller: PA Semi, Inc PWRficient Gigabit Ethernet (rev 11)
Interrupt: pin A routed to IRQ 64
00:14.1 Ethernet controller: PA Semi, Inc PWRficient Gigabit Ethernet (rev 11)
Interrupt: pin A routed to IRQ 65
00:14.2 Ethernet controller: PA Semi, Inc PWRficient Gigabit Ethernet (rev 11)
Interrupt: pin A routed to IRQ 66
00:14.3 Ethernet controller: PA Semi, Inc PWRficient Gigabit Ethernet (rev 11)
Interrupt: pin A routed to IRQ 67
Kernel driver in use: pasemi_mac
00:15.0 Ethernet controller: PA Semi, Inc PWRficient 10-Gigabit Ethernet (rev 11)
Interrupt: pin A routed to IRQ 68
00:15.1 Ethernet controller: PA Semi, Inc PWRficient 10-Gigabit Ethernet (rev 11)
Interrupt: pin A routed to IRQ 69
00:1a.0 DMA controller: PA Semi, Inc PWRficient DMA Controller (rev 12) (prog-if ff)
Interrupt: pin A routed to IRQ 128
Capabilities: [40] Vendor Specific Information: Len=50 <?>
00:1b.0 System peripheral: PA Semi, Inc PWRficient SERDES (rev 11)
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
00:1c.0 SMBus: PA Semi, Inc PWRficient SMBus Controller (rev 01)
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 70
Region 0: I/O ports at 7f0200 [size=64]
00:1c.1 SMBus: PA Semi, Inc PWRficient SMBus Controller (rev 01)
Interrupt: pin A routed to IRQ 71
Region 0: I/O ports at 7f0240 [size=64]
00:1c.2 SMBus: PA Semi, Inc PWRficient SMBus Controller (rev 01)
Interrupt: pin A routed to IRQ 72
Region 0: I/O ports at 7f0280 [size=64]
00:1d.0 Serial controller: PA Semi, Inc PWRficient 16550 UART (rev 02) (prog-if 03 [16650])
Interrupt: pin A routed to IRQ 73
Region 0: I/O ports at 7f03f8 [size=8]
Kernel driver in use: serial
00:1d.1 Serial controller: PA Semi, Inc PWRficient 16550 UART (rev 02) (prog-if 03 [16650])
Interrupt: pin A routed to IRQ 74
Region 0: I/O ports at 7f02f8 [size=8]
00:1e.0 ISA bridge: PA Semi, Inc PWRficient LPC/Localbus Interface (rev 12) (prog-if ff)
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 81
Region 0: I/O ports at 7f0400 [size=256]
Region 1: I/O ports at 7f0500 [size=256]
01:00.0 VGA compatible controller: ATI Technologies Inc RV730 PRO [Radeon HD 4650] (prog-if 00 [VGA controller])
Subsystem: Giga-byte Technology Device 21c5
Interrupt: pin A routed to IRQ 48
Region 0: Memory at 90000000 (64-bit, prefetchable) [size=256M]
Region 2: Memory at a0020000 (64-bit, non-prefetchable) [size=64K]
Region 4: I/O ports at 2000 [size=256]
Expansion ROM at a0000000 [disabled] [size=128K]
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [58] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 128 bytes
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk-
LnkSta: Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 00000000fc080000 Data: 0000
Capabilities: [100 v1] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Kernel driver in use: radeon
01:00.1 Audio device: ATI Technologies Inc RV710/730
Subsystem: Giga-byte Technology Device aa38
Interrupt: pin B routed to IRQ 49
Region 0: Memory at a0030000 (64-bit, non-prefetchable) [size=16K]
Address: 00000000fc080000 Data: 0001
Kernel driver in use: HDA Intel
05:12.0 SATA controller: ATI Technologies Inc SB600 Non-Raid-5 SATA (prog-if 01 [AHCI 1.0])
Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 248, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 212
Region 0: I/O ports at 1040 [size=8]
Region 1: I/O ports at 105c [size=4]
Region 2: I/O ports at 1048 [size=8]
Region 3: I/O ports at 1058 [size=4]
Region 4: I/O ports at 1010 [size=16]
Region 5: Memory at a0209000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [60] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [70] SATA HBA v1.0 InCfgSpace
Kernel driver in use: ahci
05:13.0 USB Controller: ATI Technologies Inc SB600 USB (OHCI0) (prog-if 10 [OHCI])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 252, Cache Line Size: 64 bytes
Region 0: Memory at a0207000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
05:13.1 USB Controller: ATI Technologies Inc SB600 USB (OHCI1) (prog-if 10 [OHCI])
Interrupt: pin B routed to IRQ 213
Region 0: Memory at a0208000 (32-bit, non-prefetchable) [size=4K]
05:13.2 USB Controller: ATI Technologies Inc SB600 USB (OHCI2) (prog-if 10 [OHCI])
Interrupt: pin C routed to IRQ 214
Region 0: Memory at a0206000 (32-bit, non-prefetchable) [size=4K]
05:13.3 USB Controller: ATI Technologies Inc SB600 USB (OHCI3) (prog-if 10 [OHCI])
Region 0: Memory at a0204000 (32-bit, non-prefetchable) [size=4K]
05:13.4 USB Controller: ATI Technologies Inc SB600 USB (OHCI4) (prog-if 10 [OHCI])
Region 0: Memory at a0205000 (32-bit, non-prefetchable) [size=4K]
05:13.5 USB Controller: ATI Technologies Inc SB600 USB Controller (EHCI) (prog-if 20 [EHCI])
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin D routed to IRQ 215
Region 0: Memory at a0209800 (32-bit, non-prefetchable) [size=256]
Capabilities: [c0] Power Management version 2
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
Bridge: PM- B3+
Capabilities: [e4] Debug port: BAR=1 offset=00e0
Kernel driver in use: ehci_hcd
05:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 14)
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Region 0: I/O ports at 1020 [size=16]
Region 1: Memory at a0209400 (32-bit, non-prefetchable) [size=1K]
05:14.1 IDE interface: ATI Technologies Inc SB600 IDE (prog-if 83 [Master PriP PriO])
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Region 0: I/O ports at 1030 [size=8]
Region 1: I/O ports at 1054 [size=4]
Region 2: I/O ports at 0170 [size=8]
Region 3: I/O ports at 0374 [size=1]
Region 4: I/O ports at 1000 [size=16]
Kernel driver in use: pata_atiixp
05:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
Subsystem: Varisys Ltd Device 1000
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=slow >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 240, Cache Line Size: 64 bytes
Region 0: Memory at a0200000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
05:14.3 ISA bridge: ATI Technologies Inc SB600 PCI to LPC Bridge
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Latency: 0
05:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge (prog-if 00 [Normal decode])
Latency: 255
Bus: primary=05, secondary=06, subordinate=06, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: a0300000-a03fffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR+
06:05.0 Multimedia audio controller: C-Media Electronics Inc CM8738 (rev 10)
Subsystem: C-Media Electronics Inc CMI8738/C3DX PCI Audio Device
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping+ SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 200 (500ns min, 6000ns max)
Interrupt: pin A routed to IRQ 217
Region 0: I/O ports at 3100 [size=256]
Kernel driver in use: C-Media PCI
06:06.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: Unex Technology Corp. ND010/ND012
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 255 (8000ns min, 16000ns max)
Interrupt: pin A routed to IRQ 218
Region 0: I/O ports at 3000 [size=256]
Region 1: Memory at a0300000 (32-bit, non-prefetchable) [size=256]
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1+,D2+,D3hot+,D3cold-)
Kernel driver in use: 8139too
A-Eon A1X1000
mechanic
Re: X1k No on-board sound. (Linux)
Postby tommysammy » Tue May 22, 2012 5:23 pm
Install LinuxMint11 and have fun with the sound ;)
tommysammy
Postby mechanic » Tue May 22, 2012 6:05 pm
??? So it does not work with Debian. ???
A-Eon A1X1000
mechanic
Postby musa » Tue May 22, 2012 9:08 pm
mechanic wrote:??? So it does not work with Debian. ???
Yes there is sound in debian.
There is no problem here with sound in Debian
Im using the hda ati sb (alsa mixer)
Peter
Postby mechanic » Tue May 22, 2012 9:19 pm
Yes, that is what I have been trying also.
Just no sound. Not even system beeps.
A-Eon A1X1000
mechanic
Postby musa » Tue May 22, 2012 9:32 pm
mechanic wrote:Yes, that is what I have been trying also.
you have moved the module package into lib / modules?
Postby mechanic » Tue May 22, 2012 9:48 pm
musa wrote:you have moved the module package into lib / modules?
Oh yes, and the PCI card works just fine.
Makes no difference which sound system I select with ALSA , only the PCI card works.
EDIT:
I wonder if there is a way to probe the IDT codec chip. Is that on the PCI bus?
A-Eon A1X1000
mechanic
Postby musa » Tue May 22, 2012 10:12 pm
EDIT:
Hmm dont know
Check that there is a group called audio and that your user is a member of this group
I switched to MPlayer as a music player as I still have a lot of noise in the Banshee.
Postby mechanic » Tue May 22, 2012 10:26 pm
musa wrote:Hmm dont know
Yup, been there, done that.
(Gotta go now, She won't be late.)
A-Eon A1X1000
mechanic
Postby trevordick » Wed May 23, 2012 8:54 am
Try installing the Xine player. I also had problems with the standard version of Debian Squeeze & Gnome desktop, which did not seem to support onboard audio out of the box. I found that some programs send there sound output through the onboard audio while others used the pci audio. System sounds always seem to be directed to the pci Audio.
However I discovered the KDE desktop and supported both onboard and pci audio out of the box and the system sound worked fine and could be directed to use either the onboard of pci audio, as did the experimental Debian Wheezy install. The MintPPC install which also works out of the box (once set up) but this is of course also based on the Wheezy iso.
Trevor
I'm just Breezin'
trevordick
A-Eon Technology
A-Eon Technology
Next
Return to Platform: AmigaOne X1000 - Linux Only
Who is online
Users browsing this forum: No registered users and 11 guests
cron
