Hello all
I have a question, when active button effects composition in the Prefs GUI to make visible the shadows of the window, when I open a window are drawn well their shadows, but when change the size of the window then not are drawn correctly, because this happens?
Gui Prefs
Window before resize
Window after resize
Lisardo.
Composite Effects
Composite Effects
Amiga 1200 / Blizzard 1260 / Mediator 1200 / Voodoo 3000 / 64 Mb / AmigaOS 3.9
Sam Flex 440ep 733 Mhz / AmigaOS 4.1 u 4
AmigaONE X1000
AmigaONE X1000
Re: Composite Effects
This is a known problem, and it is being worked on.Fernecho wrote: I have a question, when active button effects composition in the Prefs GUI to make visible the shadows of the window, when I open a window are drawn well their shadows, but when change the size of the window then not are drawn correctly, because this happens?
Kind regards,
Dennis
I understand, thank you, I thought that it was a configuration problem.A3000T wrote:This is a known problem, and it is being worked on.Fernecho wrote: I have a question, when active button effects composition in the Prefs GUI to make visible the shadows of the window, when I open a window are drawn well their shadows, but when change the size of the window then not are drawn correctly, because this happens?
Kind regards,
Dennis
Greetings
AmigaONE X1000
AmigaONE X1000
