X1000 + Sapphire X1950 GT fail ?
Postby Benny » Thu Mar 21, 2019 6:09 pm
This card, the Sapphire X1950GT boots and displays a picture on my AmigaONE 500 aka Sam460ex.
It works fine!
Putting the card in my X1000, it displays the OS41FE bootlogo but stays there forever.
Tried to boot from my SSD with Update1, and from the 41FE CD.
It is not really a great problem, I just want to run some benchmarks, but should this card simply operate fine ?
Benny
Re: X1000 + Sapphire X1950 GT fail ?
Postby ddni » Fri Mar 22, 2019 2:25 pm
Hi, that card isnt listed here:
http://hdrlab.org.nz/projects/amiga-os- ... atibility/
It may not be compatible. What drivers are you using?
ddni
Postby Benny » Wed Mar 27, 2019 2:34 pm
ddni wrote:Hi, that card isnt listed here:
Radeon HD 2.22
But no problem, I replaced the card allready by 7750's.
I just wondered that the card works 100% in my Sam460ex but not in the X1000.
Benny
Postby Raziel » Wed Mar 27, 2019 4:10 pm
Radeon HD 2.22
Probably because the sam did get firmware updates, while the x1000 still has it's years old UBoot which is known to have unsupported stuff.
Congrats on the 7750, i use one myself.
If slaughterhouses had glass walls, everyone would be a vegetarian. ~ Sir Paul McCartney
Did everything just taste purple for a second? ~ Philip J. Fry
Ain't got no cash, ain't got no style, ladies vomit when I smile. ~ Dr. John Zoidberg
Postby nbache » Wed Mar 27, 2019 6:20 pm
Raziel wrote:Probably because the sam did get firmware updates, while the x1000 still has it's years old UBoot which is known to have unsupported stuff.
The X1000 doesn't use UBoot at all, it uses CFE.
Postby Raziel » Wed Mar 27, 2019 7:59 pm
UBoot, CFE, all the same
Postby Benny » Wed Mar 27, 2019 9:18 pm
On both Amigaone’s the CFE/Uboot bootscreen is displayed, only the X1000 stays forever at displaying the OS4.1 logo.
Benny
Postby Raziel » Wed Mar 27, 2019 10:56 pm
I get these kind of "freezes" a lot (with my 7750) after a crash or freeze of a program, where i have to reboot (no matter if software or hardware reboot).
I tried to debug it with serial logs, but it's too much internals which i don't know how to rectify.
Essentially it stalls at displaying the logo screen because of something in the USB stack freezes.
I get a call on serial to some massstorage.device (where non is inserted/installed) but never a return message.
(The only hubs i have installed is one to make the USB3 front port work and one that goes to the USB input of my monitor (which provides two more simple USB ports).
What it (wrongly) defines as massstorage is beyond me.
And it's unfortunately not reproducable either.
On the very first boot it "normally" passes, on a reboot after a crash it "normally" freezes...
Ah well, the wonders of a niche system...
Postby Benny » Thu Apr 04, 2019 9:57 am
Raziel wrote:I get these kind of "freezes" a lot (with my 7750) after a crash or freeze of a program, where i have to reboot (no matter if software or hardware reboot).
<cut>
Yes, the same here. After a Grimreaper, a softreboot does not work, a hardreset does not work, only putting the machine to sleep helps.
And not always, but most of the time.
My Amigaone 500 has the same 'feature' ;)
Benny
Postby Raziel » Thu Apr 11, 2019 9:58 am
@Benny
First of all i'm glad that it's not only my machine and second, if more systems are affected maybe a CFE update could fix this behaviour?
Wasn't there talks that CFE might get an update?
Next
Return to Platform: AmigaOne X1000
Who is online
