AMD ATI Radeon HD7670 It's good for the X1000
Postby Fernecho » Mon May 14, 2018 7:55 pm
Hello everyone,
The graphic card of my X1000 has died, it is a Radeon HD7950, my question is if I can put an AMD ATI RADEON HD7670, is it compatible with the latest drivers ???.
Amiga 1200 / Blizzard 1260 / Mediator 1200 / Voodoo 3000 / 64 Mb / AmigaOS 3.9
Sam Flex 440ep 733 Mhz / AmigaOS 4.1 u 4
AmigaONE X1000
Fernecho
Re: AMD ATI Radeon HD7670 It's good for the X1000
Postby Petrol » Thu May 17, 2018 8:49 am
You should contact Hans De Ruiter, the author of the Radeon driver, directly. On his web site, there is a compatibility list for AmigaOS4.1, but I don't know if it is up-to-date.
Regards,
Petrol
Postby Fernecho » Thu May 17, 2018 2:02 pm
I think it is not compatible
AmigaONE X1000
Fernecho
Petrol wrote:Hi,
Regards,
Ok, thanks for the information, I'm going to look at Hans's website to inform me which graphics cards are compatible.
Thank you so much for everything.
AmigaONE X1000
Fernecho
Postby Fernecho » Thu May 17, 2018 7:26 pm
I have looked at the compatibility list and this card is not listed as compatible, the HD 7000 series starts with the HD 77xx (excluding the HD 7790), the HD 7670 is not supported by the AmigaOS 4 drivers.
On the other hand I have cleaned the contactors of my HD 7950 and also the contacts of the motherboard, I have reassembled it and now it works perfectly, the problem could be in the dirt of the contacts, hindering the communication between the card and the motherboard .
Subject successfully resolved.
AmigaONE X1000
Fernecho
Return to Platform: AmigaOne X1000
Who is online
Users browsing this forum: No registered users and 3 guests
