JFX/04 issue [FIXED]
Postby Zenzizenzizenzic » Fri Jul 26, 2013 12:52 am
I cannot seem to use this FS. When I change a partion to that, the machine does not boot. What am I doing wrong?
Last edited by Zenzizenzizenzic on Fri Jul 26, 2013 9:07 am, edited 1 time in total.
Zenzizenzizenzic
Re: JFX/04 issue
Postby tonyw » Fri Jul 26, 2013 1:58 am
JXFS is not bootable. The partition that contains the file "amigaboot.of" must be FFS. Your system partition can then be JXFS or SFS or whatever.
Re: JFX/04 issue
Postby Zenzizenzizenzic » Fri Jul 26, 2013 2:59 am
This isn't a boot partition. Just a storage partition (end of the hard drive, if that matters).
Zenzizenzizenzic
Re: JFX/04 issue
Postby sundown » Fri Jul 26, 2013 4:28 am
Zenzizenzizenzic wrote:This isn't a boot partition. Just a storage partition (end of the hard drive, if that matters).
The block size must be 512 for JXFS to work. Other then that, verify JXFileSystem is in sys:kickstart & has not been commented out in kickstart/kicklayout & is loaded.
Ken
sundown
Re: JFX/04 issue [FIXED]
Postby Zenzizenzizenzic » Fri Jul 26, 2013 9:07 am
Looks like it was the block size. Must have missed that. SIGH. Thanks!
Zenzizenzizenzic
Postby Christopher Follett » Fri Jul 26, 2013 7:54 pm
Ive been having this issue. It wont mount the partition.
Will check block size.
Resolute and Industrious
__________________
New Products
Christopher Follett
AmigaKit
AmigaKit
Return to Platform: AmigaOne X1000
Who is online
Users browsing this forum: No registered users and 1 guest
cron
