Bug in shared library version of newlib's libstdc++.so?
Postby nexus » Thu Apr 14, 2011 11:57 am
Ok, then. Thanks for this official AOS4 support forum and I take the opportunity
to rephrase my c++ problem with the SDK/Compiler/Linker, which I mentioned
earlier only at the temporarily amigans.net site.
I really hope some solution or fix can be found by the AOS4 dev team.
Thanks in advance for any helpful replies!
Here's the bug description:
It seems there's a problem with newlib, when throwing an error and linking
with the shared object version of libstdc++.so.
See the following simple code:
#include <iostream>
using namespace std;
class DummyClass {
  public:
    DummyClass(){};
int main( int32_t argc, char** argv ){
  DummyClass dc;
  try{
    cout<<"throw error"<<endl;
    throw dc;
  /*}catch(DummyClass dcr){*/ // same problem occurs when used instead of the next  line
  }catch(DummyClass &dcr)
     cout<<"Dummy error!"<<endl;
  }catch(...){
     cout<<"Unknown error"<<endl;
  return 0;
Compiling and statically linking by
"g++ Main.cpp -o test"
gives you a binary called "test" which outputs correctly
"Dummy error!" to stdout.
When compiling and linking with libc.so:
g++ -use-dynld Main.cpp -o test"
Then "test" causes a GripReaper:
Stack trace:
      libstdc++.so:_Z16get_adjusted_ptrPKSt9type_infoS1_PPv()+0x28 (section 10 @ 0x7429c)
      libstdc++.so:__gxx_personality_sj0()+0x4D4 (section 10 @ 0x74f18)
      module aOS4.1:SObjs/libgcc.so at 0x6DEDD070 (section 0 @ 0x9074)
      libstdc++.so:__cxa_throw()+0x74 (section 10 @ 0x75448)
      a.out:main()+0x154 (section 8 @ 0x644)
      native kernel module newlib.library.kmod+0x00001f4c
      native kernel module newlib.library.kmod+0x00002b98
      native kernel module newlib.library.kmod+0x00002d5c
      a.out:_start()+0x170 (section 8 @ 0x170)
      native kernel module dos.library.kmod+0x0001b524
      native kernel module kernel+0x00036290
      native kernel module kernel+0x00036310
However, when changing the code a little by just commenting
the DummyClass-specific exception:
  try{
     throw dc;
 // }catch(DummyClass dcr){
 //    cout<<"Dummy error!"<<endl;
  }catch(...){
everything works fine also with the shared object version and
test outputs: "Unknown error" as expected.
So, it seems, that you can't catch specific Exceptions?
The same problem appears when the Exception is defined
and thrown within another "shared object"-library on AmigaOS4.
A suggested solution given in the thread at the temporarily amigans.net site
was to always inherit a self-defined exception from "public std::exception".
In the example case above, this means, to redefine the class 'DummyClass' by :
class DummyClass : public std::exception {
  public:
    DummyClass(){};
And indeed, it works, when the class is defined within the compiled binary.
However, the same GrimReaper still seems to appear, when that self-defined
exception (including the inheritance from std::exception) is defined within a shared
library object (.so) which is dynamically linked against the main program and where
such a self-defined exception is tried to be caught.
To give more concrete information:
I compiled CLucene for AOS4 as a shared library and build my own application around it.
In the CLucene.so-library an Exception is defined which I have to catch in my application
and which causes then the above mentioned GR.
nexus
nexus
Re: Bug in shared library version of newlib's libstdc++.so?
Postby Hans-Joerg Frieden » Thu Apr 14, 2011 2:57 pm
I'll have a look at this ASAP. It could be an issue with an unsupported reloc.
Hans-Joerg Frieden
Postby ssolie » Thu May 19, 2011 5:20 am
Hans-Joerg Frieden wrote:I'll have a look at this ASAP. It could be an issue with an unsupported reloc.
I hit this problem way back when I was trying to port C++ Boost using newlib and shared objects.
I think I still have a very simple test case around here someplace in case you need it.
It had to do with throwing exceptions if I recall correctly. It has been a while since I worked on it.
ssolie
Postby nexus » Thu May 19, 2011 2:48 pm
A fully functional shared C++ Boost Library, would be very appreciated!
Of course, a fix for this exception problem, too. :-)
nexus
nexus
Postby Trev » Sat Jun 18, 2011 10:43 pm
Any word on whether this will be resolved in the next OS update?
Trev
Postby Trev » Sat Dec 24, 2011 6:31 pm
Fixed in Update 4?
Trev
Postby alekc » Tue Dec 27, 2011 11:19 pm
Trev wrote:Fixed in Update 4?
Looking at my test results I can confirm that it is fixed in U4 :D . If anyone wants I can post my sample code based on original example from problem report post.
alekc
Postby kas1e » Wed Dec 28, 2011 10:51 am
@Trev
Dunno if i do something wrong , but i just trying to use example above, and with / without -use-dynld , on update3 and on update4, i have in shell output:
throw error
Dummy error!
And no crashes.
Trying that on my peg2.
kas1e
Return to SDK Support
Who is online
