Alpyre wrote:I've encountered some mistakes as I go through the documentation and noted them down. Here they are for your attention:
application.doc:
- Identifiers READPREFS_LastAppDocs,
WRITEPREFS_LastAppDocs,
REGAPP_Name
...are explained but they are not defined in the headers.
- a typedef c_time is mentioned but not defined in the headers.
- AppLibMsg and AppLibOpenPrintDocMsg structs are mentioned but not defined
in the headers.
With the exception of #?PRESF_LastApppDoc these seam already addressed in the docs, it may be that the lastAppDocs is not implmented yet (not sure what it means TBH).
intuition.doc:
WA_Flags is not mentioned in SetWindowAttr
It's not an error, WA_Flags is not support by SetWindowAttrs(), only by GetWindowAttrs().
bsdsocket.doc:
- Error identifier EACCES is misspelled as EACCESS (many times)
- SIOCSIFADDR is misspelled as SIOCIFADDR
- BIOCSETIF is misspelled as BIOSETIF
- IFNAMSIZ is misspelled as IFNAMSIZE
I'll leave those for someone else (with more knowledge) to comment on
