LoadSeg() or VERSION command crash with corrupted binary
Postby zzd10h » Sat Feb 11, 2017 11:37 am
Trying
BPTR seg = LoadSeg(file);
to determine the version of a file crashs on incomplete binaries (half downloaded file).
Trying OS4 Version command on the same file crashs too.
Do you know a way to safe use LoadSeg ?
Crash log for task "version"
Generated by GrimReaper 53.19
Crash occured in module elf.library.kmod at address 0x0216F980
Alert number: 0x80000003
    native kernel module elf.library.kmod+0x00000e40
    native kernel module elf.library.kmod+0x00000fec
    native kernel module elf.library.kmod+0x000071cc
    native kernel module elf.library.kmod+0x00007524
    native kernel module dos.library.kmod+0x00041d98
    native kernel module dos.library.kmod+0x0001b3d4
    module version at 0x7F5FFA88 (section 4 @ 0xA64)
    module version at 0x7F5FFEAC (section 4 @ 0xE88)
    module version at 0x7F60099C (section 4 @ 0x1978)
    version:_start()+0x184 (section 1 @ 0x1B0C)
    native kernel module dos.library.kmod+0x000255c8
    native kernel module kernel+0x000420ac
    native kernel module kernel+0x000420f4
PPC disassembly:
 0216f978: 38600000   li                r3,0
 0216f97c: 4e800020   blr
*0216f980: 9421ffe0   stwu              r1,-32(r1)
 0216f984: 7c0802a6   mflr              r0
 0216f988: 90010024   stw               r0,36(r1)
Re: LoadSeg() or VERSION command crash with corrupted binary
Postby salass00 » Sat Feb 11, 2017 7:25 pm
You could just scan the file contents for the "$VER:" sequence that starts the version tag.
salass00
Postby zzd10h » Sat Feb 11, 2017 8:32 pm
thank you for the reply,
therefore no way that loadseg() or version command don't crash ?
Postby xenic » Sat Feb 11, 2017 10:36 pm
zzd10h wrote:thank you for the reply,
I just aborted the D/L of a large file with Odyssey and then used the Version command to try to find the version. It took a second or 2 to complete but the Version command reported it didn't find a version and did not crash. However, when I cut a binary command in half, then the version command crashes. The problem only seems to affect binary programs and not other truncated or corrupt files.
Return to SDK Support
Who is online
