envvar naming
envvar naming
Postby Raziel » Sun Nov 08, 2015 5:29 pm
Hi devs,
Are envvars limited to letters when using them in DOS scripts?
I tried to distinguish some vars by using a "." and the scripts started to act ill.
Example:
This script works as expected.
requestchoice >ENV:rcnumtest "Test" "Test" "One" "Null/Cancel"
if $rcnumtest EQ 1
   echo "One"
   SKIP Finish
endif
echo "Null"
LAB Finish
While this script doesn't...
requestchoice >ENV:rcnum.test "Test" "Test" "One" "Null/Cancel"
if $rcnum.test EQ 1
   echo "One"
   SKIP Finish
endif
echo "Null"
LAB Finish
Just want to know if it' s meant to be that "special" chars aren't allowed in envvars or if it's a limitation or maybe even a regression?
Thanks a lot
If slaughterhouses had glass walls, everyone would be a vegetarian. ~ Sir Paul McCartney
Did everything just taste purple for a second? ~ Philip J. Fry
Ain't got no cash, ain't got no style, ladies vomit when I smile. ~ Dr. John Zoidberg
Location: A haunted Castle somewhere in the Bavarian Mountains
Re: envvar naming
Postby thomasrapp » Sun Nov 08, 2015 6:00 pm
You can enclose the variable name in braces (a.k.a. curly brackets) if you need special characters, for example ${rcnum.test}
Re: envvar naming
Postby Raziel » Mon Nov 09, 2015 7:29 am
Arrgh, i should have read the DOS manual before i start doing things...of course, stupid me
Thanks Thomas
Re: envvar naming
Postby ssolie » Tue Nov 10, 2015 1:32 am
thomasrapp wrote:You can enclose the variable name in braces (a.k.a. curly brackets) if you need special characters, for example ${rcnum.test}
I'm having a tough time finding this on the AmigaOS wiki.
Where was this documented in the original Amiga reference books?
AmigaOS Development Team Lead
Be authentic. Get AmigaOS.
ssolie
Re: envvar naming
Postby colinw » Tue Nov 10, 2015 8:52 am
http://wiki.amigaos.net/wiki/AmigaOS_Manual:_AmigaDOS_Using_Scripts
Under "Dot Commands", .bra and .ket can also redefine the character used.
colinw
Return to General Developer Support
Who is online
Users browsing this forum: Google [Bot] and 8 guests
