(solved) Hieronymus not working on Sam440 ?
Postby ChrisH » Sun Aug 16, 2015 12:32 pm
I tried Hieronymus on my Sam440, but all it outputs is this obscure error message:
ˆFailed to acquire samples, the interrupt server does not work or interrupt context is null
Does it work on anyone else's Sam440? Any idea what the problem could be?
EDIT: It works when I use a different boot partition, so looks like something's borked on my first boot partition.
ChrisH
Re: (solved) Hieronymus not working on Sam440 ?
Postby corto » Sun Aug 16, 2015 1:59 pm
ChrisH wrote:I tried Hieronymus on my Sam440, but all it outputs is this obscure error message:
Great to see you try Hieronymus!
Can you confirm you use the last version (0.22) from os4depot?
What is the format of your first boot partition?
Don't you boot 2 versions of the system?
I would like to understand the problem you faced. And if you have some questions or comments, you're welcome!
corto
Postby ChrisH » Sun Aug 16, 2015 7:15 pm
corto wrote:Can you confirm you use the last version (0.22) from os4depot?
Yup.
It's failing on AmigaOS4.1 Update 4 (!), but works on AmigaOS4.1 Final Edition. However, both boot partitions are *extremely* customised (so that they can share exactly the same settings, etc), and it is quite possible I broke something on the older (Update 4) partition. I should probably do a clean install on that partition...
I guess there's no chance of you getting Hieronymus working on the X1000 ? That's my main machine.
P.S. Hieronymus already confirmed my suspicion about obscenely slow speed being due to a particular algorithm (procedure), something I could NOT do using GCC's profiling mode (-pg), so Hieronymus has done it's job :-)
ChrisH
Postby corto » Sun Aug 16, 2015 11:13 pm
No, that's not necessary. Hieronymus started to work on Sam440 with a given version of the rtg.library (I will be able to provide the exact version if necessary).
I modified the sources and with the version 0.22, Hieronymus should have printed the required version of rtg.library (that certainly came out around the update 5).
About the port to the X1000, the hope came when I acquired a machine and then I faced a problem. But recently, I thought about an idea to circumvent it. I will have to test that.
I'm very pleased to see Hieronymus helped you!
corto
Postby ChrisH » Tue Sep 01, 2015 11:13 pm
corto wrote:I'm very pleased to see Hieronymus helped you!
Something else which would really help (and I'm surprised it isn't already implemented) is for Functions to be sorted by their Count, so that the most-frequent functions are at the top (as typically these are what you are interested in).
ChrisH
Postby corto » Thu Sep 03, 2015 1:38 pm
Sure, it would be useful ... I think it is not implemented yet because not so fun and creative to do (but I created a ticket about that one year ago in my bugtracker).
But recently, I worked on several points:
- I've added stats provided by the performance monitor for a given delay (if you know the Linux tool called "perf"). That's done on the MicroAOne and when it's done with a good software design and working, I will add the X1000 support.
- About the chance to have the profiling working on the X1000, as you asked: After new investigations, I found that the performance monitor was unfortunately not usable for sampling. So the other chance will be to have a low-level and periodic interrupt source.
corto
Re: Hieronymus not working on Sam440
Postby capehill » Mon Jul 10, 2017 12:10 pm
On my Sam440 Hieronymus 0.22 crashes. Stacktrace points towards elf.library. Anybody else with the problem?
Crash log for task "hieronymus"
Generated by GrimReaper 53.19
Crash occured in module elf.library.kmod at address 0x01576614
Alert number: 0x80000003
Register dump:
   0: 0156E504 5C148EE0 00000000 5C148E50 5B6C4E2C 5C149028 00000000 06180842
   8: 01DCD9A2 00000000 5C148E70 00001000 4A444242 58F4FB10 80000004 80000001
  16: 80000002 58F40000 58F40000 58F50000 58F4759C 58F483BC 00000000 80000004
  24: 00000001 5B6C4E2C 5C148E50 5B6C4DB0 5C148FB0 00000000 00000000 00000000
   0:              nan              791              804              208
   4:                2            271.8             78.8              208
   8:                2              128            271.8              255
  12:              nan            65536                0                0
  16:                0                0                0                0
  20:                0      1.17664e-38                0                0
  24:                0                0                0                0
  28:                0                0                0                0
FPSCR (Floating Point Status and Control Register): 0x82000000
           Machine State (msr) : 0x0002F030
                Condition (cr) : 0x90380000
      Instruction Pointer (ip) : 0x01576614
       Xtended Exception (xer) : 0x00000000
                   Count (ctr) : 0x00000000
                     Link (lr) : 0x00000000
            DSI Status (dsisr) : 0x0000FF01
            Data Address (dar) : 0x00040100
680x0 emulated registers:
FPU0:                0                0                0                0
FPU4:                0                0                0                0
Symbol info:
Instruction pointer 0x01576614 belongs to module "elf.library.kmod" (HUNK/Kickstart)
Stack trace:
    native kernel module elf.library.kmod+0x00008254
    native kernel module elf.library.kmod+0x00008248
    native kernel module elf.library.kmod+0x000004d0
    native kernel module elf.library.kmod+0x000005e0
    hieronymus:Bosch_StopAcquisition()+0x3fc (section 1 @ 0xBA8)
    hieronymus:main()+0x490 (section 1 @ 0x13E4)
    native kernel module newlib.library.kmod+0x00001ea0
    native kernel module newlib.library.kmod+0x00002d84
    native kernel module newlib.library.kmod+0x00003074
    hieronymus:_start()+0x170 (section 1 @ 0x16C)
    native kernel module dos.library.kmod+0x00026698
    native kernel module kernel+0x0003e9a8
    native kernel module kernel+0x0003e9f0
PPC disassembly:
 0157660c: 7c7a1b78   mr                r26,r3
 01576610: 813c0048   lwz               r9,72(r28)
*01576614: a1490030   lhz               r10,48(r9)
 01576618: 2f8a0000   cmpwi             cr7,r10,0
 0157661c: 419e0054   beq-              cr7,0x1576670
System information:
CPU
 Model: AMCC PPC440EP V1.3
capehill
Return to General Developer Support
Who is online
Users browsing this forum: No registered users and 6 guests
