AOS4.1 Final Edition does not start
This forum is for Pegasos II specific issues.
Postby Reth » Sun Jun 21, 2015 8:57 pm
Hi everybody,
when I try to boot AOS4.1FE from CD Bootloader starts and entire kickstart is loaded. But then nothing else happens anymore AOS4.1FE does not boot further.
Any idea what goes wrong here and what to try?
Many thanks in advance!
Bye
Reth
Re: AOS4.1 Final Edition does not start
Postby Evillord68 » Wed Dec 16, 2015 8:38 pm
Do you still have this problem?
Which drives are shown in bootmenu?
Evillord68
Postby tonyw » Wed Dec 16, 2015 11:07 pm
As a betatester, you should have a serial terminal connected so that you can capture the serial debug output. With that output, you should be able to see what is going wrong.
Postby amc » Tue Oct 03, 2017 11:33 am
Hello,
I have experienced the same behavior with my Peg2 board. Serial terminal didn't show anything useful to debug, but in my case it depended on Peg2 firmware: I had rev. 1.0, strings colors weren't correctly recognized and booting hung after loading Kickstart in text mode without switching to graphics but upgrading to 1.1 Smartfirmware fixed the issue.
Hope this helps.
Regards
Alessio
amc
Postby Reth » Tue Oct 03, 2017 3:36 pm
Hi again,
since my safe backup also hung on startup I inserted AOS4.1 FE CD into PegII these days and this time it booted flawlessly so that I was able to install it.
Thank you for your support!
Bye
Reth
Return to Platform: Pegasos II
Who is online
Users browsing this forum: No registered users and 3 guests
