Aone 500 freezing
Aone 500 freezing
Postby Joeled » Sat Mar 17, 2012 5:41 pm
Ok i have a big problem with my Aone 500 freezing after 1-3 hours. Like everyone else i have os4.1.4 installed but i have played around alot. I installed samba(for idiots) and added latest samba fs. Everything is working really great but smts it feels like smtg in the background is working really hard. If i try to delete a file from workbench it takes 20 seconds before i get a meny to delete it. This doesnt happend all the time so i m thinking maybe samba is working overtime? I started snoopy and its going crazy. After 1 min its so slow i cant do anything than just see what it reports.
What do you think?
Joeled
Re: Aone 500 freezing
Postby Joeled » Sat Mar 17, 2012 10:03 pm
Ok heard from a friend that there is a bug in samba thats eating all memory.
you should remove the line samba:bin/nmbd under sys:prefs:internet/servers
Joeled
Postby cha05e90 » Sat Mar 17, 2012 10:58 pm
Joeled wrote:Ok heard from a friend that there is a bug in samba thats eating all memory.
I have the same Samba version running on my A2000's, SAM440ep and Pegasos II for *years* now without any problem. There should be no need to remove the nmbd from the services list in Roadshow. It looks more like a configuration mismatch. Did you try to run Snoopy while the machine get's slower and "is working really hard"? This may give a hint on what's going on in the backround.
One tip: If you by accident misconfigured your Samba setup to have the same machine/netbios name as another machine in your local network, *then* nmbd goes mad and writes tons of error info into the log file at "Samba:log/nmbd.log". You might check that file - it can grow to several gigabytes...
cha05e90
Postby Joeled » Sat Mar 17, 2012 11:48 pm
@cha05e90
It was kind of impossible to use snoopy when nmbd was active. I use static ip-adresses so its not abt that. I removed that line and now snoppy isnt working that hard and i m still able to connect to my nsa210. Well, maybe i did smtg wrong but i followed samba idiot´s guide :-D
Now another problem and thats how i can start blender? I get a error "couldnt create minigl context". Tried a demo from os4-depot ASG and i get could not create an opengl context. Using radeon 4650 with resolution 1680*1050 ARG. I have minigl.library 2.5 in my sys:libs
Joeled
Postby cha05e90 » Sun Mar 18, 2012 12:32 am
Joeled wrote:@cha05e90
If you only want to connect your SAM to the nas you can completely deactivate/deinstall Samba. You do not need it - you *only* need SMBFS!
AFAIK Blender needs to be restricted to a 16Bit screen and can't be used in every resolution. It might even be possible that you need to install some software based warp3d.library replacement to use Blender (AFAIK minigl relies on Warp3D). Maybe broadblues, the porter of Blender, might give you an more educated hint how to start Blender.
cha05e90
Postby Joeled » Sun Mar 18, 2012 10:18 am
@@cha05e90
Ok, how do i deactive it? Under prefs:internet and servers i have two lines
Netbios-ssn
swat
Can you tell me exactly what to do? I only need to connect to my nsa210 bec i have all my stuff there. Is there any tool that can save info for me when my aone 500 freezes after a copule of hours? Snoopy only works as long as the computer is active.
Joeled
Postby Joeled » Tue Mar 20, 2012 9:24 am
I disabled screenblanker and now the system has been up 10 hours without freezing?
Joeled
Postby cha05e90 » Tue Mar 20, 2012 10:51 am
Joeled wrote:@@cha05e90
Netbios-ssn
swat
If you don't want to completely deinstall Samba, deactivationg all Samba entries under Internet/Servers should be sufficient. See link: http://www.ruthe.info/wp-content/uploads/2012/02/samba4.jpg. You'll see the "Active" column, go into each entry, set it to "Inactive" and all entries should read "No" in the "Active" column, that's it.
Regarding the info - *if* (and only *if*) you're able to do a warm reboot after that freeze, then you might be able to catch a debug log by typing "dumpdebugbuffer" in a shell. If you need to cold restart, this doesn't work.
cha05e90
Return to Platform: AmigaOne 500 and Sam series
Who is online
cron
