OS4.1 Enhancer ....USB gone
Postby mjnurney » Sat May 20, 2017 9:18 pm
hi guys
Ive just updated my Sam based AmigaOne with the enhancer pack and after a reboot ...no USB.
no keyboard or mouse which makes it tricky to use :-)
i wonder if its been disabled in Boot ...hang on
Update:
Fixed , had to power off completely and remove the power.
reboots didn't fix it..very odd.
Working now.
mjnurney
Re: OS4.1 Enhancer ....USB gone
Postby amigakit » Mon May 22, 2017 1:31 pm
The Enhancer Software does not change or modify anything in USB, must have been the Sirion USB bug where it times out. Unplugging the mouse/keyboard and re-plugging in should recover it.
www.amigakit.com Amiga Computer Store
amigakit
AmigaKit
AmigaKit
Postby mjnurney » Fri May 26, 2017 8:33 pm
amigakit wrote:The Enhancer Software does not change or modify anything in USB, must have been the Sirion USB bug where it times out. Unplugging the mouse/keyboard and re-plugging in should recover it.
it didn't in this case, i had to power down completely before the USB would come back. a reboot didn't work.
It seems ok now , the USB forgets its their every so often but thats ok but unplugging and replugging seems to work now.
mjnurney
Return to Platform: AmigaOne 500 and Sam series
Who is online
Users browsing this forum: No registered users and 5 guests
