SiI3114 on Sam 460 EX
Postby tonyw » Sat Apr 19, 2014 1:32 pm
Due to the recent demise of the SiI3512 in my Sam 460, I have fitted an SiI3114 and connected my two drives to ports 0 and 1.
U-Boot times out trying to read ports 2 and 3. Is there a U-Boot variable that I can set to prevent it from trying to init drives 2 and 3?
In the old days on the A1 it would have been something like "IDE_MAXBUS = 2". Is there a corresponding variable for the Sam?
Re: SiI3114 on Sam 460 EX
Postby Spectre660 » Sat Apr 19, 2014 2:00 pm
Try
s4sii_maxbus=1
Postby javierdlr » Sun Apr 20, 2014 12:13 am
Spectre660 wrote:Try
s4sii_maxbus=1
I - Configuring sii3512ide through UBOOT envvars
Currently sii3512ide is configurable through the following UBOOT envvars :
- sii3512ide_verbose
Legal values are : set to anything makes the driver verbose at boot time.
Default if unset : driver silent.
- sii3512ide_maxbus
Legal values are : 0 (no SATA interface at all),
1 (only primary SATA interface), and
2 (both SATA interfaces)
Default : if you don't set this envvar, sii3512ide will use both SATA interfaces.
I - Configuring sii3114ide through UBOOT envvars
Currently sii3114ide is configurable through the following UBOOT envvars :
- sii3114ide_verbose
- sii3114ide_maxbus
Legal values are : 0 (no IDE interface at all),
1 (only primary IDE interface), and
2 (both IDE interfaces)
Default : if you don't set this envvar, sii3114ide will use both IDE interfaces.
javierdlr
Postby tonyw » Sun Apr 20, 2014 5:42 am
@Javier: I said U-Boot, not OS4.
@spectre: Thanks, that seems to be the right name to use.
Unfortunately, I can't find a suitable number for "s4sii_maxbus". My two devices (DVD and HDD) are connected to the two connectors on the end of the card (connectors 0 and 2). They appear in U-Boot as devices 0 and 1 respectively, and in OS4 as units 0 and 2. If I connect the HDD to either of the other two connectors (1 or 3), then U-Boot can't boot from it.
With s4sii not set at all, device 0 is the DVD, device 1 is the HDD and device 2 times out. U-Boot does not try to reset device 3.
If I set s4sii_maxbus to "1", then only the DVD is recognised and FLB can't find a boot device (naturally).
If I set s4sii_maxbus to "2", then the DVD is recognised, device "1" times out and device 2 becomes the HDD. The system boots OK, taking the same time as if s4sii_maxbus were not set at all. I don't know why the HDD changes from "device 1" to "device 2".
If I set s4sii_maxbus to "3", then it's the same as not setting it at all (naturally).
I think the only thing I can do is to leave s4sii_maxbus not set and set "ide_reset_timeout" to a short value, eg 2 seconds, until I can get to a flea market and buy a new 3512. Of course, I could always plug in another (old) drive for it to recognise as device 2. Hmm...
Postby yogi » Sun Apr 20, 2014 1:44 pm
I have a sii3114 card in my AmigaOne 500. The settings I have for it are s4sii_maxbus=1, and boot1=s4siicdrom, and boot2=s4sii. What is strange about this card, is how the drives have to be connected. I have the DVD drive on port 0, but my hard drive is on port 2. For some reason, I could not get port 1 to work. I have had this setup running since I have owned the machine and it is stable.
On a side note, I wish acube would have put a sii3512 or sii3114 on the motherboard instead of what they went with. Other than that I love this computer.
Yogi
yogi
Postby joerg » Sun Apr 20, 2014 2:21 pm
yogi wrote:I have a sii3114 card in my AmigaOne 500. The settings I have for it are s4sii_maxbus=1, and boot1=s4siicdrom, and boot2=s4sii. What is strange about this card, is how the drives have to be connected. I have the DVD drive on port 0, but my hard drive is on port 2. For some reason, I could not get port 1 to work. I have had this setup running since I have owned the machine and it is stable.
The old AmigaOne XE version of U-Boot only supported 2 ports of a sii3114 (the "master" drives, like the AmigaOS 4.x drivers it didn't use SATA directly but PATA emulation), and IIRC they are differently numbered in U-Boot and the AmigaOS 4.x drivers which makes it even harder to use the correct ports, on AmigaOS the ports which can be used by U-Boot are units 0 and 2 of sii3114ide.device. Maybe it changed in the Sam460 version of U-Boot, but I doubt it.
joerg
Postby tonyw » Mon Apr 21, 2014 1:45 am
No, the numbering is the same (wrong) order.
Postby joerg » Mon Apr 21, 2014 1:56 am
tonyw wrote:No, the numbering is the same (wrong) order.
I didn't only mean the numbering, but the U-Boot sii3114 driver being limited to 2 ports. It's strange that it tries to access ports 2 and 3 if it doesn't support them anyway ...
Maybe the Sam460 U-Boot supports the sii3114ide_conf variable, although it's for the OS4 drivers, to disable ports and/or set a drive type. Or maybe s4sii_conf instead for U-Boot.
Edit: Something else to try: Set sii4_maxbus to 1 and swap your drives, ATAPI drives (DVD/CD) take much longer to respond after a reset than ATA ones (HDs), if U-Boot first accesses your HD on port 0 (U-Boot port number 0) that may be enough delay until it gets to port 1 checking the DVD drive.
joerg
Postby Slayer » Mon Apr 21, 2014 12:42 pm
hmmm
I've just recently been using my sii3114 in both my X1000s and didn't add any settings or similair and it just goes whatever device I plug in, of course I'm not trying to boot from it.
It's quite handy being able to use more than 4 SATA devices, is there actually a recommended SATA card we can get for our latest machines which has been deemed pick of the bunch? Don't mean to derails the thread :D
Slayer
Postby tonyw » Mon Apr 21, 2014 3:22 pm
The X-1000s use CFE which is much more recent thatn U-Boot. I guess CFE supports all four ports while U-Boot only supports two on some platforms.
Haven't yet tried out Joerg's latest suggestions. Maybe in the morning.
Return to Platform: AmigaOne 500 and Sam series
Who is online
cron
