Delock PCI Express Sound Card 7.1
Postby lozspd4 » Sun Jul 28, 2013 3:40 pm
Hi All
Just wanted to Report that the Above Mentioned card works fine with the sam460ex Board under Os4.1 update 6, make sure jumper 16 on the MotherBoard is open before fitting, To set the Card up in AHI First make sure the eny24ht driver is in the Audiomodes Directory in devs: if it not it will proberly be in storage: move it over. If its not there make sure your using update 6 with amiupdate,Same goes for the AHIdriver draw then reboot then open PREFS: AHI ,First of all in Ahi menu under EDIT click on Reset to Defaults THIS IS IMPORTANT to Reduce PROBLEMS BY SETUP.
Select ENVY24HT:HiFi 16bit stereo ++ using first Music Unit set Frequency to 41000 or 48000, then change to unit 0 SET Frequency the same value then set channel to 2, do this for all unit 0-3. Then under Advanced Settings set volume Scaling to Safe,dynamic to reduce clipping in sound when programs try to play with a volume over 0db.
Note That this card can only use sample rates up to 48000Hz no Higher. Then Enjoy reduces cpu usage by 15%ish and costs a fith of what the esi costs OK it can only sample to 48000Hz unless you use a TOP Notch Sound studio/System Thats more then enough.
Any one want to Know where i Ordered it Please PM as im not sure if it would be classed as advertisng here in the forum if i posted the Link.
Im very pleased with the card and everything works what i,ve chucked at it. ok the Mixer doesn,t work but i never used it any way,i got remote for my sound system for the volume.So Know my pciex slot isn,t jealous anymore of the others lol:
Thanks Acube and Os4.1 CREW
Regards Laurence
lozspd4
Re: Delock PCI Express Sound Card 7.1
Postby Interrogative » Mon Oct 19, 2015 9:01 pm
Good day,
I set up my Vantec PCIe 7.1 (an Envy24DT) card according to your instructions above. I have a 5.1 surround sound speaker set up connected to my card. I only get sound out of the first set of L-R speakers. I have no center/bass or rear speakers working. In addition, the sound is as quiet as earbuds. Is there any way of getting the other speakers working and boosting the volume through AHI prefs?
Motherboard: SAM460ex lite @1017 MHz 2 GB DDR2 SOLD
PCIe 4x: XFX Radeon HD 7750 Core Edition 1 GB SOLD
PCI: SYBA SY-SA3512-2R 2 Port SATA SOLD
PCIe 1x: Vantec UGT-S110 7.1 Audio SOLD
OS: AmigaOS 4.1 FE SOLD
Interrogative
Postby davebraco » Mon Oct 19, 2015 9:19 pm
@ Interrogative
Your card looks pretty similar to mine. I don't think we've already utilities to test channels others than main left/right.
About the quiet sound, if you setup the card correctly in AHI, did you well plugged the cable shown on this picture :
http://www.vantecusa.com/gl/product/show_pro_image/456/2
(Sorry if it seems to be a stupid question)
davebraco
Postby Interrogative » Tue Oct 20, 2015 12:59 am
davebraco wrote:@ Interrogative
Not stupid at all. I had not supplied that information. All but the gray connector is connected (It is a 5.1 speaker system while the card is 7.1).
I recently discovered that I have decent volume in all but the rear speakers when using Tunenet or Amiga AMP. Liveforit MPlayer andSMTube are silent, using only one set of speakers.I guess I will have to contact the authors of those programs to see how they use AHI.
Interrogative
Postby broadblues » Tue Oct 20, 2015 1:01 pm
I get the same "problem" sound on 5:1 sound system that some gave me a while back, stereo srcs only play on the front two speakers and the bass. Note that's driving it from a stereo input or a CD in the built in drive not from a computer.
That makes me think this is the way it works for stereo via 5.1 unless you convert it in software first.
Postby duga » Tue Oct 20, 2015 9:50 pm
broadblues wrote:I get the same "problem" sound on 5:1 sound system that some gave me a while back, stereo srcs only play on the front two speakers and the bass. Note that's driving it from a stereo input or a CD in the built in drive not from a computer.
Isn't that how it's supposed to work?
duga
Postby Interrogative » Tue Oct 27, 2015 7:04 pm
All connected speakers are now working with MPlayer and SMTube. I can only speculate what could have been causing the problem. Perhaps it was how AHI initialized during those sessions? All I know is that it is working now.
Interrogative
Postby davebraco » Tue Oct 27, 2015 7:41 pm
Good to hear to your problem is solved!
davebraco
Return to Platform: AmigaOne 500 and Sam series
Who is online
Users browsing this forum: No registered users and 4 guests
