ppc programs problem with powerpc.library
Postby lozspd4 » Fri Feb 15, 2013 5:19 pm
Hi All
As posted before i have just got a new AmigaOne 500, and am now installing it, i have os4.1 till updates 6 installed then installed some ppc programs like WO2097, Amigawriter ,earth2140,when starting the programs i get a cannot open PowerPC.library v7 press ok and the program doesnt start.
I am using the original PowerPC.library that came with os4.1.
On the other Hand amigawriter ,earth2140 in 68mk work, even Nightlong Freespace Napalm works. I have installed a RADEON HD5450 Gfx Card which i dont think is the Problem.
If anyone else has experienced this and can shed some light maybe im doing something wrong on the Installation.
Many Thanks in Advance
Laurence
lozspd4
Re: ppc programs problem with powerpc.library
Postby Petrol » Sat Feb 16, 2013 12:09 am
There is no WarpOS emulation for Sam460 in the powerpc.library. Only classics, Aone SE/XE, pegasos and Sam440 are supported.
Regards,
Petrol
Petrol
Postby lozspd4 » Sun Feb 17, 2013 12:58 am
Hi Petrol
Thanks for the reply saved me a lot of time trying to figure it out comming from a os4.1 classic system. i wasn,t aware of that. One learns something new every day.:))
Regards
Laurence
lozspd4
Postby thomasrapp » Sun Feb 17, 2013 10:52 am
Why does WarpOS emulation need hardware dependency? Isn't it possible to make a generic library which just wraps WarpOS functions to OS4 functions?
Postby kas1e » Sun Feb 17, 2013 11:37 am
@thomasrapp
Problem is that powerpc.library is no more in develop as i see, and seems author never will worry about it anymore. So if someone new (by someone i mean ThomasRapp:) ) will write such a new library from scratch and make it opensource, then there is some chances to have better warpos support in end.
kas1e
Return to Platform: AmigaOne 500 and Sam series
Who is online
Users browsing this forum: No registered users and 3 guests
cron
