No large hd partition with 3.1.4
Postby C64er » Sat Nov 10, 2018 2:36 pm
I've burned and installed a 3.1.4 Rom for my A2000. When I setup 3.1.4, I can only see 4gb out of the 16gb card in my scsi2sd card.
When I replace the 3.1 Rom and load OS 3.9 all is fine, I have a 2gb and a 12gb partition.
At my wits end with this and nearly $100 investment.
C64er
Re: No large hd partition with 3.1.4
Postby thomasrapp » Sat Nov 10, 2018 7:43 pm
There are new tooltypes for HDToolbox which let you override certain limits.
Set LIMIT_4GBYTE to OFF or FALSE to remove the white bar at 4GB.
Also enable the "Direct SCSI Transfer" checkbox in the advanced options.
Postby C64er » Sun Nov 11, 2018 1:15 am
thomasrapp wrote:There are new tooltypes for HDToolbox which let you override certain limits.
Thanks a million Thomas, that did the trick. Will have to file that tip away.
Dan
C64er
Postby thomasrapp » Sun Nov 11, 2018 10:38 am
You should read the docs. There is a lot of information in the FAQs.
Postby C64er » Sun Nov 11, 2018 3:59 pm
thomasrapp wrote:You should read the docs. There is a lot of information in the FAQs.
RTFM, what a novel idea. LOL
I'll do that. I loaded it on top of OS 3.9 and like it so far, sure there's plenty of tweaks that'll be fun to play with.
Dan
C64er
Postby kolla » Mon Nov 12, 2018 7:46 am
Yet nothing regarding CrossDOSFileSystem, I find zero info on how to replace FAT95 for hard drives.
kolla
Return to Platform: Classic
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
