Blizzard PPC with GREX
Postby SimonV » Tue Aug 09, 2016 6:36 pm
Should I even consider trying ? Does someone already tried it ?
SimonV
Re: Blizzard PPC with GREX
Postby Benny » Wed Aug 10, 2016 4:12 pm
SimonV wrote:Should I even consider trying ? Does someone already tried it ?
Yes, from the hardware support department:
DCE GREX 1200 or 4000 – Support for Voodoo 3 and RTL8029 ONLY! Experimental Support in Amiga OS 4.1 Final Edition and up.
Benny
Postby DarrenHD » Tue Aug 30, 2016 7:15 am
Yes Blizzard + GREX + Voodoo works. Any version of the GREX is fine, fixed or unfixed. Voodoo 3 and RTL8029 are the *ONLY* cards that will work, though. Believe me we tried to get other cards to work (such as sound cards) but it just didn't work properly even though we setup the PCI card correctly. There must be some funkiness going on and undocumented stuff unfortunately. So use a Voodoo 3 and RTL8029 in a GREX setup and use Paula for sound.
DarrenHD
Return to Platform: Classic
Who is online
Users browsing this forum: No registered users and 4 guests
