Configuring sound card
Postby TWynn » Wed Nov 18, 2015 8:19 am
I have a A1200 with Blizzard PPC card, Mediator PCI 1200TX, and a Creative SoundBlaster 128 model CT4750 attached to the third (from top) PCI slot. I have been trying to configure my sound card in 4.1FE but have been unsuccessful.
I have attempted to insert the driver for the sound card using the Elbox Multimedia CD by copying the sb128.audio to the Devs:AHI drawer and the SB128 file into the Devs:AudioModes drawer. But when I open AHI preferences I cannot locate the setting under Modes settings tab. Am I doing something wrong?
Does 4.1FE support SoundBlaster 128 card, or does it only support ESS Solo-1 cards?
Any help would be greatly appreciated.
TWynn
Re: Configuring sound card
Postby davebraco » Wed Nov 18, 2015 2:49 pm
I would suggest you to take a look at this link :
http://os4depot.net/index.php?function= ... 128ahi.lha
davebraco
Postby xenic » Wed Nov 18, 2015 7:07 pm
TWynn wrote:I have a A1200 with Blizzard PPC card, Mediator PCI 1200TX, and a Creative SoundBlaster 128 model CT4750 attached to the third (from top) PCI slot. I have been trying to configure my sound card in 4.1FE but have been unsuccessful.
You also need the audiomodes file for your card. The mode files go in SYS:Devs/AudioModes. If you found the sb128.audio driver on the Elbox CD, the audiomodes file should be there too.
Postby DarrenHD » Mon Dec 14, 2015 7:10 pm
Hi, AmigaOS 4.1FE doesn't directly support the Soundblaster, because it requires DMA (which we don't have for the Mediator), but there is a work around you can use:
http://www.hd-zone.com/2011/06/using-a- ... x-classic/
Darren
DarrenHD
Return to Platform: Classic
Who is online
Users browsing this forum: No registered users and 3 guests
cron
