USB Joypad problem
USB Joypad problem
Postby nubechecorre » Tue Dec 25, 2018 2:20 pm
I have bought a Snes usb joypad clone that works fine under Windows. On the AmigaOS 4 side it is recognized from the system and it partially works but there is a problem when I plugged into my Amigaone system. Under AmigaInput when I try to calibrate it, a requester appears and says:"This AmigaInput unit is not configurable - Problems with Axis Pair components in LIBS:AmigaInput/Generic_usb.driver" .. Indeed when i try to play some games with, for example, vice, I can move the player one in all directions except down.. or some time the player stay down.. is there any workaround for this problem?
http://www.os4games.it
Sam440ep mini-itx
Classic System:
Amiga 1200
Radeon 9250 128Mb VRam
Voodoo 3 3000 16Mb VRam
DVD-RW LG Dual Layer
SoundBlaster PCI 128
Cocolino Interface Elbox
AmigaOne White Mouse
nubechecorre
Return to General AmigaOS
Who is online
Users browsing this forum: No registered users and 5 guests
