Preparing a new HD for installing 0S4.1 FE
Postby JosDuchIt » Fri Aug 18, 2017 3:01 pm
Guidance on this? URL?
When on mediatoolbox you hit install, then on rdb editing install again you are asked to select AmigaOne boot code
= SLB—v2 ?
JosDuchIt
Re: Preparing a new HD for installing 0S4.1 FE
Postby xenic » Fri Aug 18, 2017 4:57 pm
JosDuchIt wrote:Guidance on this? URL?
= SLB—v2 ?
I would also like to know the answer to that for X5000. Some systems have SLB, X1000 has amigaboot.of and I don't see any boot file for X5000.
Postby Spectre660 » Fri Aug 18, 2017 6:23 pm
Yes for Sam440 and Sam460 .
= SLB—v2 ?
Postby Spectre660 » Fri Aug 18, 2017 6:24 pm
for X5000 the boot code is on the microsd card .
(X5000 manual page 10)
= SLB—v2 ?
Postby xenic » Tue Aug 22, 2017 7:49 pm
Spectre660 wrote:for X5000 the boot code is on the microsd card .
In that case, what do you enter for AmigaOne boot code in the Edit RDB window of MTB??
Postby Spectre660 » Tue Aug 22, 2017 11:53 pm
The X5000 boot drive does not need any "A1 booter "so don't install anything.
Sam460ex
X5000
Postby tonyw » Wed Aug 23, 2017 12:14 am
xenic wrote:In that case, what do you enter for AmigaOne boot code in the Edit RDB window of MTB??
As Spectre660 said, the SLB was only used on the SEs, XEs, µA1, Sam 440s and 460s. No other platform used it and it's not required in any modern machine.
Postby Elwood » Tue Sep 05, 2017 10:05 pm
With your OS4 CD, you have an "Installation guide" that explains this, under "Harddisk setup with Media Toolbox". It should explains it for all machines with Uboot.
For machines based on Open Firmware, you may find enough information here: http://www.amedia-computer.com/amiga/do ... nglish.pdf
Philippe "Elwood" Ferrucci
Sam460 owner
AmigaOS 4 betatester
Elwood
Return to General AmigaOS
Who is online
Users browsing this forum: No registered users and 11 guests
