DvPlayer 0.76 and mouse pointer (OS 4.1 Final Edition)
Postby samo79 » Thu Nov 12, 2015 3:01 pm
I noted a difference between DvPlayer running under update 6 and then in Final Edition
If i use DvPlayer under the Final Update the mouse pointer will never disappear when i watch a video in fullscreen, instead with the update 6 (at some point) the mouse pointer will be hidden as it should be
Not a big problem of course, but maybe worth to mention ...
samo79
Re: DvPlayer 0.76 and mouse pointer (OS 4.1 Final Edition)
Postby hotrod » Thu Nov 12, 2015 11:58 pm
Hmm... I'm always using the mouseblanker commodity for this function, are you sure that that isn't what's missing? I didn't know that programs hidd the mousepointer in AOS since that is available.
hotrod
Postby K-L » Fri Nov 13, 2015 2:57 am
samo79 wrote:I noted a difference between DvPlayer running under update 6 and then in Final Edition
Since overlay is totally trashed in Final Edition with DvPlayer, you'd better wait far an hypthetical update of the program.
K-L
Postby samo79 » Fri Nov 20, 2015 11:17 am
Well, i will I expect an OS fix (if it is a problem introduced in the FE), if it worked before then it should continue to work now .. :roll:
samo79
Return to General AmigaOS
Who is online
Users browsing this forum: No registered users and 8 guests
