In "printer preferences" gui you have a printer type FILE
Clicking on the driver options you get a requester File Printer options " notably with choice clipboard/File
I can't make anything happen when selecting this printer type and trying to print something from say Notepad.
Is there some doc about this printer type ?
How can you use it?
Printer preferences printer type "FILE"
Re: Printer preferences printer type "FILE"
Confirmed.
Not even the requester opens up.
Either a bug or not yet supported feature.
I remember this from 3.1 days, though, it should, if running normally, "print" the text from e.g. Notepad into the given file (I know it worked back then)
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
Printing to file seems to work with GraphicDump (SYS:Utilities/GraphicDump) and AmiPDF (SYS:Utilities/AmiPDF/AmiPDF) but not with NotePad.
- Janne Peräaho
- broadblues
The FILE printer type only works with graphics based printing, not with programs like NotePad that essentially save text directly to PRT:
