/* Gadget example
# define __USE_INLINE__
# include <proto/exec.h>
#include <proto/intuition.h>
#include <proto/gadtools.h>
#include <proto/exec.h>
#include <proto/dos.h>
#include <intuition/intuition.h>
#include <libraries/gadtools.h>
#include <stdio.h>
#include <stdlib.h> // exit instead of Exit obsolete
char name[30] = "Joseph";
APTR visual;
/* Type of gadgets to display */
ULONG Gadgetkinds[3] = {STRING_KIND, INTEGER_KIND, BUTTON_KIND }; /// text entry not TEXT or NUMBERKIND
struct TextAttr topaz8 = {
(STRPTR)"topaz.font", 8, 0, 1
/* Data for gadget structures */
struct NewGadget Gadgetdata[3] = {
63, 36, 172, 17, (UBYTE *)"Name", &topaz8, 1, PLACETEXT_LEFT, NULL, NULL,
62, 60, 175, 17, (UBYTE *)"Age", &topaz8, 2, PLACETEXT_LEFT, NULL, NULL,
111, 105, 54, 31, (UBYTE *)"Calc", &topaz8, 3, PLACETEXT_IN, NULL, NULL
/* Extra information for gadgets using Tags */
ULONG GadgetTags[] = {
(GTST_MaxChars), 256, (GTST_String), name, (STRINGA_Justification), STRINGCENTER , (TAG_DONE),
(GTNM_Border), TRUE,(GTIN_Number), 3, (TAG_DONE),
(TAG_DONE)
int main() {
struct Screen *pubScreen;
struct Window *myWindow;
struct Gadget *myGadgets[3], *glist=NULL, *gad1;
int closewin = FALSE, i;
struct IntuiMessage *msg;
ULONG msgClass;
/* Lock screen and get visual info for gadtools */
if (pubScreen = LockPubScreen(NULL)) {
if (!(visual = GetVisualInfo(pubScreen, TAG_DONE))) {
printf("Failed to get visual info.\n");
exit(5);
else {
printf("Failed to lock screen.\n");
exit(5);
/* Create the gadget list */
if (!(gad1 = CreateContext(&glist))) {
printf("Failed to create gadtools context.\n");
exit(5);
/* Create gadgets specify gadget kind, a Gadget, NewGadget data and extra tag info */
for (i=0; i<3; i++) {
Gadgetdata[i].ng_VisualInfo = visual;
if (myGadgets[i] = gad1 = CreateGadgetA(Gadgetkinds[i], gad1, &Gadgetdata[i], (struct TagItem *)&GadgetTags[i])) {
printf("Gadget %d created.\n", i);
else
printf("Failed to create gadget %d.\n",i);
/* Open window and specify gadget list (glist) */
myWindow = OpenWindowTags(NULL,
WA_Left, 10, WA_Top, 15,
WA_Width, 280, WA_Height, 180,
WA_IDCMP, IDCMP_CLOSEWINDOW | IDCMP_GADGETUP,
WA_Flags, WFLG_SIZEGADGET | WFLG_DRAGBAR | WFLG_DEPTHGADGET | WFLG_CLOSEGADGET | WFLG_ACTIVATE | WFLG_SMART_REFRESH,
WA_Gadgets, glist,
WA_Title, "My Window",
WA_PubScreenName, "Workbench",
TAG_DONE);
GT_RefreshWindow(myWindow, NULL); /* Update window */
while (closewin == FALSE) {
Wait(1L << myWindow->UserPort->mp_SigBit);
msg = GT_GetIMsg(myWindow->UserPort);
msgClass = msg->Class;
GT_ReplyIMsg(msg);
if (msgClass == IDCMP_CLOSEWINDOW) {
closewin = TRUE;
if (myWindow) CloseWindow(myWindow);
/* Free gadgets */
if (glist) FreeGadgets(glist);
if (visual) FreeVisualInfo(visual);
if (pubScreen) UnlockPubScreen(NULL, pubScreen);
return(0);
How do i have to make the string center in the STRING_kind gadget ?
(STRINGA_Justification), STRINGCENTER, is not accepted
I followed the gadtools.doc i think?
Solved it:
with
#include <intuition/iobsolete.h>
(STRINGA_Justification), GACT_STRINGCENTER,
